Question about HP Computers & Internet
When I put on my hp compaq6000 laptop the power doesn't stay on.The fan starts and the battery orange light appears and goes off
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Sound possibly Like a Ram problem, where the Ram has become unseated, and may require  taking the bottom off the laptop and seeing if it  does need re-seating.
Here's the Guide for you to look at :
Posted on Dec 03, 2008
M1160n wont boot windows xp nor two internal fans
Step 1:
Lets try this...
Unplug the cpu
Step 2:
remove the battery from on the mainboard
Step 3:
press and hold the power button for 30 seconds
Step 4:
release it
Step 5:
put the battery back in, plug in and turn on , it should work fine..
Step 6:
If that fails replace the power supply..
Dec 28, 2012 | HP Media Center m1080n (PC099A#ABA) PC...
When i putu the power cable on, the led light blink once and goes off. the screen is black. no fan is moving or any sound.
You should try to start your computer without the battery installed. If that doesn't work, you should try another power supply. If that doesn't either do the trick, it could be the motherboard causing the trouble.
Jun 14, 2011 | HP 530 Notebook PC
When i turn on my dell 110 mini the light goes from white to orange and stays there the screen doeset boot or anything
Remove battery, open the access panel on the bottom carefully remove the ram sticks. Put them safely on a piece of paper so that a static charge doesn't ruin them, also touch something metal before you try and remove. If your computer doesn't beep at all when you power it back on your CPU, GPU, or MB are bad. If it beeps then there is still hope.
Jun 10, 2011 | HP Mini 110-1037NR Netbook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
My HP 6720 won't switch on. When connected to the power source, a steady blue light comes on (normal) then goes to a light blue then goes blank. If I press the 'on' button, a flashing orange light appears...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 19, 2010 | HP Computers & Internet
Compaq Presario laptop C300 - issues (orange light)
Sometimes when a PC gets stuck in hibernation mode, the only way to reset it is to remove the CMOS battery for 10 minutes and replacing it. It resembles a large watch battery and is usually located near the center of the motherboard.
Dec 16, 2009 | HP 435768-001 - Compaq Presario C300...
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
Computers & Internet Logo
46 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
