Question about NAD T751 Receiver
Is there a reset button for the NAD Surround Sound Receiver T 751
Our NAD developed an intermittent buzzing on all channels and then stopped working altogether, it's too old for warranty. Does anyone know if there is a reset button or have any other ideas? Thank you!
  • 4 Answers
The only reset that i know of is to unplug it for 15 to 20 minutes. Hope this helps.
Posted on May 07, 2009
How do i fix the buzzing on my nad t741 5.1 receiver?
Bad screening on your cables.
Braided cable coax touching signal cable
Wires in close proximity to power wires
Interference from 'always on' appliances like fridges, freezers and heating boilers.
Disconnect each lead in turn. If that doesn't fix it, it is an appliance.
Apr 16, 2016 | NAD Audio Players & Recorders
Subwoofer channel no longer has output
Is your sub powered (amplifier built-in)? If so, connect your MP3 player directly to the sub input and see if you hear audio. If you do hear audio, check for cable problems from Panasonic to sub input. If the sub is unpowered then it's either the speaker wiring, an intermittent sub and/or your Panasonic at fault.
Mar 22, 2015 | Panasonic Sa-ht70 Home Theater Receiver 5...
Denon receiver not working surround output
If everything is connected correct, the only thing I can think of, is you don't put in a surround signal. If you only feed 2 way stereo, only two speaker will work. Also if you switch to stereo, the other channels will stop working. Check the cables, the settings and the input.
Jun 15, 2014 | Pioneer VSX-D511 Receiver
The left main channel not working. hook any speaker to it and putting my ear close, it has a very low hollow sound, almost a hum. would there be fuses, a reset, or something on each channel or something...
There is no seperate fuse but it seems likely that the left side preamp or the power amp section had opened up a fusible resisitor that could have shut the section.
Now the only way out is to take a voltage or signal test with the right - working- channel as a reference . Please attempt only if you are familiar if not it will end up with further damage as the sections are very delicate. Testing with a signal will confirm the faulty section to narrow down your search.
Aug 23, 2011 | NAD T742 Receiver
NAD T-763 receiver. cannot get surround sound. all speakers work. should the 7.1 and or surround be connected to the receiver and what else. stereo works fine....two front speakers, in stereo mode. ...
Have you looked at the manual? There is no internal source that would produce 7.1 audio other than the test tones. Attach a multichannel source according to ITS manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T763-Receivers-manual/id/8043bh646/t/2/
Apr 19, 2011 | NAD T763 Receiver
5 yr old Maytag fridge stops working
solve dvb skystr 2TV//MAC:00-08-c9-A2-32-9F/satllit Eutelstw3 7E
Dec 05, 2009 | Maytag Refrigerators
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
GE - SIDE BY SIDE MODEL TFX25JR - Continous HUM
Probably the condenser fan motor is going out they will often make noise for a long time before anyone notices. Get it looked at soon. overheating the compressor on that old of a fridge could spell trouble.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
Technics Surround Receiver - Clicks, but doesn't function
There could be a number of reasons for this. It woyld help if you could indicate what resistors you changed. The circuit designation should be marked on the PC board. Please post those here and I'll look further and provide some possible solutions.
Thanks,
Dan
Jul 20, 2009 | NAD 712
Open Questions:
NAD T751 Receiver Logo
754 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
