Question about LG LRTN22320 Top Freezer Refrigerator
Occasional buzzing LG Refrigerator: GR 722R The fridge will intermittently start buzzing (louder than normal) - if i touch the fridge (ie open door, bump side) it will stop momentarily. It isn't a constant problem but it is a new one. Thanks
MNTECH
  • 1543 Answers
SOURCE: Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
Posted on Apr 11, 2009
  • 112 Answers
SOURCE: Dents in fridge door
Contact an automotive "paintless dent removal" provider-- they are mobile, so they can come to your home.
Posted on Jul 09, 2009
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
SOURCE: MY LG fridge model GR- M562 YLY
I am in search of an LG PCB board LBN 22515sb
Posted on Sep 10, 2009
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
How do I fix a buzzing sound in my fridge?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 09, 2015 | Refrigerators
LG fridge making loud noise
Bonjour,
jeepers are we talking about a wheeze, a clunk, a whirr, a buzz, a rattle, a hum, random modulated or cyclic, low or high frequency, persistent or intermittent? Or could you just be hearing fan noise.
If it sounds like tin pieces clinking against something metallic. The fan blades may be striking ice or frost or the shroud.
Could be a bad or worn fan motor bearing, or a defrost problem causing frost build up.
Just a FYI
Some LG models have been reported online as having many many operating issues.
Hope this helps
Jul 11, 2012 | LG Refrigerators
LG Side by Side refrigerator - ongoing intermittent beep - not door alarm
Have you cleared and cleaned the condenser and checked the water filter?
Apr 28, 2012 | LG Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
(1.Contents are no longer getting cold. Thermometer jumps to the upper sixties and everything feels close to warm. (2.Inner edge of doors are very hot to the touch. (3. Prior to this, it would make an...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 22, 2010 | Refrigerators
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
My fridge is making a loud nosies and it is not stopping
that is the auto defrost fan working,nothing to worry about.
Apr 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Jan 23, 2009 | LG LRFC25750 Refrigerator French Door
LG LRTN22320 Top Freezer Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
