Question about Cyberhome CH-DVD 300 DVD Player
Where can I get parts for a CH-DVD 300 player??
Need parts for a CH-DVD 300........(planetary gear on drive motor for laser carrage)......Dave
  • 85 Answers
Hi dave.has it split?i have had some success in replacing this cog from a scrap cd player,as these cogs are all near enough the same item so if you have a scrap cd kicking around,its worth a go,as i dont think the part you need is commercially available on its own....
Posted on Dec 12, 2008
  • 814 Answers
Try this website just put it into your address bar. They have lot of information on repair these dvd players, and might have spare parts for sale.Hope this helps you with your problem.
Posted on May 16, 2009
My CyberHome CH-DVD 300 Player Not working CD, Only Disply "CyberHome DVD appear in Screen". I am in Near Tambaram. Please send Nearst Service centre Contact No. and Address.
Not reading anymore DVD movies disc or CD musics disc.The DVD laser eye head reader it is dead.Can't be repair must be replaced,not worth it well cost the same price as a new DVD player unit,if repair by a tech and have to buy parts for it.Basic DVD player unit are very cheap these day.U can buy a new one just a basic DVD player only will cost u like $40.
Aug 22, 2011 | Cyberhome CH-DVD 300 DVD Player
Shows "Loading" but won't play
You can try cleaning the laser head and drive carriage. Clean the laser head with cotton swabs and small amount of isopropyl alcohol.Rub the swab back and forth across the head of the laser, do not apply to much pressure or you knock the laser out of alignment.Check the carriage, clean the the guide rails and check the belts and gears. All should be cleaned and checked to see if still in functional condition. if all this does not help you with your problem ,then the laser unit has probably weaken through age and can no longer function properly. Hope this helps you with your problem.
May 15, 2009 | Cyberhome CH-DVD 300 DVD Player
My dvd player pauses while playing and then skips ahead to a different chapter. What can I do to fix it if anything?
This player may need cleaning and it may be overheating with age. Try cleaning out the unit and the laser head. Use cotton swabs to clean the laser head with a small amount of isopropyl alcohol and using the swabs to clean the drive carriage and drive rails.Check for loose belts and gears try cleaning them off to remove dust and may want to apply a very small amount of lithium grease on the rails and gears to insure smooth movement. Do not use to much or you will cause more problems with the carriage being too lubed and moving too much. also try putting a fan on the unit passing air through the vents or moving the player to a area with good air circulation.If this does not help you may need to have the unit tested out for problems with the laser drive circuits and the carriage. Hope this helps you with your problem.
Apr 21, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome Mini DVD player not playing
Mine too. been getting bad for several weeks now. The gear on the motor that runs the laser carriage has probably split (I know mine has) so when the split section,(which now has more space between 2 of it's teeth than it can tolerate) comes around to the other gear, it jams up and that is likely the reason you have a flashing green light. The laser can't track correctly, if it can move at all. I hate to throw away the player for a 10 cent part, but have had NO LUCK finding the tiny gear as yet. I'm gonna open some internal dvd players that someone threw away with the rest of their computer and see if that works. Bet a lot of these will be heading for the landfill soon, as more gears give up the ghost.
Mar 15, 2009 | Cyberhome CH-DVD 300 DVD Player
I have a CyberHome DVD 300. It will not load disc.Indicates that no disc inserted. I have cleaned the disc to no avail.
you will need to remove the cover and clean the laser eye with rubbing alcohol and cotton swab (q-tip)
Mar 04, 2009 | Cyberhome CH-DVD 300 DVD Player
CyberHome DVR 1200
Main drive motor that spins the dvd replace with generic, when the motor gets old contacts get
corroded or woren out, ive taken apart and cleand sucessfully for a nother year on the motor.
or purchas another, the dvd must spin fast at the start, ive owend 3 of these pups for about 7
years. its the drve moter the lasers are good and strong.
Mar 01, 2009 | Cyberhome CH-DVD 300 DVD Player
DVDs won't play..
Does it appear that the movie is playing, look at the counter. Thanks, Mike
Nov 04, 2008 | Cyberhome CH-DVD 300 DVD Player
CH-DVD 300 Freezes Then Skips Ahead
Chech the laser lens rails maybe got dirt clean it take off the grease they got.
Jun 26, 2008 | Cyberhome CH-DVD 300 DVD Player
Dvd player makes a ticking noisse and wont play
It sounds like you may have broken the DVD carrage which is drive by a motor and gear system. This could be as simple as putting the gear back on track or as hard as replacing the carrage itself. I would suggest that you get a qualified technician to perform this task because having some experience with this I have had to repair the carrage and laser assembly when folks tried to do this on their own. I hope this helps.
Feb 02, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
Cyberhome CH-DVD 300 DVD Player Logo
111 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
