Cannot exit registration screen - Computers & Internet
  • vegeta0264
    vegeta0264 May 11, 2010
    Hold CTRL ALT and DELETE buttons and find the window and hit end task.
  • 733 Answers
Ctrl+alt+del or win buton
Posted on Nov 24, 2009
Cannon 2002n E355-0005 error
Hi
Please follow the below procedure to enter Service Mode
1. In standby mode, press the "Settings/Registration" key.
2. Press the "Reset" key.
3. Press the "Back" key.
4. Press the "Settings / Registration" key.
5. The service mode screen is displayed.
Use the "Back" key to exit Service Mode
COPIER> FUNCTION> CLEAR> ERR; and then turn OFF and then ON the power.
Still have an error after following that steps, please call at 1800-204-4427. I can solve you out.
Dec 17, 2016 | Cannon Office Equipment & Supplies
Showing error 047-212
That is an OCT2 error, exit error. If it happens every time or right when you turn on the machine it's either a defective exit sensor or exit pwb. The error itself indicates that the paper is late to get to that sensor so could also be from the registration section below, possibly a registration clutch slipping. Look at the print on the page and see if it's centered correctly.
Feb 29, 2016 | Xerox CopyCentre C123 Copier
How do i solve an error e000-0000 canon ir 2202
Canon iR2202
Hi
Jul 24, 2015 | Canon Office Equipment & Supplies
How can I enter service mode on canon ir 2202?
Jan 19, 2015 | Canon Office Equipment & Supplies
C020 ON ESTUDIO 4511
There's a paper jam while the paper is trying to exit the printer. The definition of the error is saying that the leading edge of the paper has reached the exit sensor, but the other end of the paper hasn't yet. Because it's jammed...
It could just be a regular paper jam that needs to be cleared, or it could be a faulty exit sensor or a faulty registration roller, or registration sensor. I'd try clearing the jam thoroughly, and then try printing again. If it's a recurring error then you may need to call someone to replace a faulty part...
Jan 27, 2011 | Toshiba e-STUDIO 4511 Printer
CANNON PC745 SAYS PAPER JAM. NO PAPER JAMMED.
The problem is normally on the exit sensor.Please check the exit sensor if its in the right possition.If the exit sensor is in the right position,also check the registration sensor if its sitting in the right position.Normally the problem is that the sensors (either the 'exit ' or 'registration' sensors) will be not in their correct position.If the two sensors are ok,there should be a small paper lleft in the machine
Brighton2m
Apr 16, 2010 | Canon Office Equipment & Supplies
Registration problem konina 7065
timing adjustment, perform the following.
1. Access the 36 mode (power the machine ON while holding down on the 4 and 7 keys.
2. Press [2] Image adjustment.
3. Press [3] Timing adjustment
4. Press [3] Lead edge timing adjustment
5. Press [Copy Screen]
6. Load 11x17 paper into tray 1, make a copy of the pyramid chart, and check the output.
Standard value: 3mm max.
7. If the lead edge original amount is different to the standard value, press the C button while pressing the P button.
8. Enter a value from the numeric keys on the screen, and press (SET) key.
Setting range: 0 (small) to 99 (large)
1 Step = 0.064mm.
9. Repeat steps 5 to 8 until the lead edge original erasure amount becomes the standard value.
10. Press the [PREVIOUS SCREEN) key to return to the Timing Adjustment Menu Screen.
11. Power the machine OFF/ON to exit the 36 mode.
PLEASE NOT THIS IS A LEADEDGE ADJUSTMENT.THE REIGIST ADJUST IS THE SAME STEPS JUST CHOOSE REGISTRATION OPTION ,AND MAKE SURE TO FOLOW PROPER DIRECTION.
Jul 02, 2009 | Sharp AR C250A Color Copier
Can't run game
kill the setup at the end with taskmanager.
Dec 03, 2008 | Video Game Consoles & Games
Registration
I am not sure if this is the same model as my phone, but I pressed the exit button and then pressed the select button. The display says something like, hold Base Page button, so do that, then the phone will beep, let you type in a handset name, and you are set to go.
Aug 06, 2007 | GE 21028GE3 Cordless Phone
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
