Question about Koss KS5190 System
Koss KS5190 Display mode stuck
I accidentally changed the display from "TV Image" to "PAL/NTSC" in the Display menu and now the picture is rolling/flipping. The user manual is no help. Is there some way to change the setting back to the way it was before? Thanks!
  • Anonymous Dec 16, 2007
    I am having the same problem. My picture is rolling/flipping. How do I fix
    the problem?
I'm not ranked and I'm not a Guru, but I can solve this picture rolling when the problem is "the video was accidently changed from NTSC to PAL and you can't see what your doing to get it back". You will need the remote control unit. First, remove the disc from the tray. Now, turn the unit off with the power button. The tray will close by itself. After the display on the front of the unit goes out, turn the unit back on using the remote control. This will let you know the remote control unit is working. When the power comes back on and the display on the front of the DVD player says, "NO DISC", with the remote control and (very important) while pointing the remote at the player, (Remember to point the remote before pressing any buttons) press the "Down Arrow" button 3 times. This will take you to the "Display" box. Now, press the "Right Arrow" button 1 time. This will take you to the "TV Image"box. Now, press the "Down Arrow" 1 time, this will take you to the "PAL/NTSC" box. If you have done everything as I have tried to clearly lead you blindly to your destination. Press the "OK" button 1 time and the picture on the screen will stop rolling and change from black & white to color. You will have now changed your video output from PAL to NTSC. If you press "OK" again, it will start to roll again. If this did not take care of your problem, turn the player off and try it again.
The previous problem solvers were on the right track, but the track was rough and they just about derailed the train. Thanks to them, I had a track to follow. I had no other information, except what I found on "Fixya.com". MR. CD
Posted on Dec 08, 2009
All you have to do is disconnect the componet cable or s video and connect the regulard video cable and you shoud get a picture to change it. or whlie the dvd try is out, press the down arrow on ur remote 4 time the right push, then down 1 and push to the left and it shoulg change back.
Posted on Oct 03, 2008
Click it again
Posted on May 03, 2007
Have sound and a black / white picture ? through our sky box
change the output to pal or ntsc on the sky box, then it should display in colour. If that doesnt work change the input on the tv to pal or ntsc.
Apr 17, 2011 | NEC 60XP10 TV
I have a Philips DVP-3010 DVD player which I purchased in Europe and thus it was set to PAL video output mode. Connecting it to a US television (which understands only NTSC) and playing a DVD produces a...
Check that the TV doesn't have the option to display PAL transmissions. It might be able to do it via any of the connectors. Otherwise your best option is to find a TV that can indeed convert both signals, or get a converter box.
Apr 04, 2017 | Philips DVP3020 DVD Player
How to Change NTSC/Pal ?
press the button again
or try taking out the
DVD
Jan 10, 2010 | Televison & Video
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Change from PAL to NTSC
To begin, the first and second problems are completely unrelated.
If you bought a PAL TV and are playing an NTSC source, the result will be an invalid format. The two sources are not compatible. However, there are converters available, see: http://www.converters.tv/signals/ntsc_to_pal.html (just as an example).
To the second user. My first guess is that you need to select the proper input on your TV. Look for the "input" button on your TV remote and toggle through each input until you see a picture. The problem may be more complicated than that, but, to troubleshoot, I need to know: what TV you have, how many devices and what devices are hooked to the TV.
Mar 28, 2009 | Koss KS3102 System
I,ve touch a function and my dvd plays but it is Black and White and the image rotate, I know that I went into picture ...i believe and set it to something else cannot bring it back to normal function DVD...
yes , i can help,> open dvd tray, your player will go to menu but it will be jumping so look to bottom of screen to tell what function you are in. scroll down till you see "display lets you display picture etc." when you see this at bottom of screen hit enter and and hit bottom arrow you will see pal/ntsc option hit enter again and your picture will return to normal good luck.
Nov 26, 2008 | Koss KS3112 DVD Player
VCR not working for some cassettes
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US. And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL. Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV, Then, again, using the Remote of the TV, select Menu, and then select AUTO in System. In all likelihood your problem should get solved.
May 13, 2007 | RCA VR605HF VHS VCR
Sony Mobile DVD MV-7101 Display is Black and White
Try pressing the arrow up on your monitor while it is on the PAL mode. This is what I just tried on my systema and it switched from PAL to NTSC.
Jan 07, 2007 | Sony MV-7101DS Car DVD Player
Koss KS5190 System Logo
333 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Steve K
Rick
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
