Whille working in Excel 2007 whenever I press Ctrl-C or Ctrl-V or Ctrl-Z the error popsup and only option is to shut down excel and loose unsaved jobs.
Major changes in system: Recently I have updated Visio.
Comments:
Dec 04, 2008
- 1. Same error. Microsoft Visual Basic :System error &H80004005
(-2147467259). Unspecified Error
After pressing 56 times OK the popup goes.
Same problem occurs when Ctrl-V.
Dec 04, 2008
- The solution is irrelevant. I am enquiring about the erorr that is within an excel worksheet not across worksheet.
1. Open a blank workbook, and type TEST in the first cell (A1).
2. Select the cell and press Ctrl-C. Do you get the error? If so, what is the error message?
3. If you don't get the error, select any other blank cell and press Ctrl-V. Do you get an error? What is the error message?
~~Cheryl
Same Problem
Feb 09, 2009
-   I get the same &H80004005 Visual Basic error in Excel (2007 with Win XP)anytime I use the hot keys like CTRL+P, even ina new blank book They work OK in Word
-   I get the same &H800040005 error whenever I use the hot keys like CTRL+P in Excel only, even from a new blank book The hot keys Work OK in Word. -   Guest
Jan 28, 2009
-   I have the same problem. Applies to all workbooks (new and old). I can no longer use shortcut keys at all. -   rdpharr
Jan 27, 2009
-   I have the same excel error but in a newly-created workbook i have no error.-   miguelaguiar
Your workbook might be corrupted. Try this:
1. In Excel, right-click any worksheet tab, and then click Select All Sheets.
2. Right-click any worksheet tab, and then click Move or Copy.
3. In the To book box, point to the arrow, and then click (new book).
4. Click to select the Create a copy check box, and then click OK.
5. On the File menu, click Save.
6. In the Save As dialog box, type a new file name, and then click Save.
See if you still get the error in the newly-created workbook.
~~Cheryl
Comments:
Dec 04, 2008
- So your error occurs no matter which workbook you're in, and even if you copy all your sheets to a new workbook?
~~Cheryl
Actually the problem is from the Eurotool.xla in your Excel that is checked by default.
The workaround is to uncheck the Eurotool add-in, and if you never need it again, you`re done.
The solution is to uninstall and re-install Office2003 SP3.
To uninstall SP3, you will need to modify the registry. First you need to find the KB applicable to your Office SP3 installation, usually tho, it's 923618.
Find that number in your registry, there`s a key in your right-hand pane that needs to be changed, where it says Uninstallable (value of 0 needs to be changed to 1) then you will be able to uninstall SP3 and the problem is solved.
You can from that point on, re-install SP3 without getting the error again.
This problem occurs at the install or uninstall of IE7.
Hello dear
I am also getting same issue on excel so I was getting many problem to work in MS Excel 2007. So I have solved it this issue and I am happy to share the solution with you all.
Solution:
Click on Excel Button which are displaying on left top corner.
Click on Excel Options.
Then click on Add-Ins option.
You can find a Manage field in the bottom. Select Excel Add-Ins and click on Go button
You will find a Add-Ins window. Please un-check all Add-Ins except Analysis toolpak and Analysis toolpak VBA.
Click on OK button.
Close excel file and open again excel file.
Now you will resolve this issue and didnt get any problem again.
Thanks
Muhammad Waseem Alvi
Software Configuration Management Engineer
Lahore - Pakistan
Was this helpful?
Yes
No
17 people thought this was helpful
Popular Solutions for Microsoft Office Professional
Microsoft Office Professional 2007 Full Version for PC
I recently installed a trial version of Mircosoft Office home and student. I've lost the product key...
(More)
I recently installed a trial version of Mircosoft Office home and student. I've lost the product key needed for security purpose. Howdo I get the product key number
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
