Question about Epson Stylus Photo 925 InkJet Printer
Photo Printer I tried to print a photo on regular paper and the image was there but came out mostly yellow. What setting do I need to change in order to have a clear picture?
  • 202 Answers
Sina, Does the photo print good using photo paper? How regular of a paper? Do all other colors have ink? What program are you printing the photo from? Have you tried printing from a different program? Some programs send varying information to printers. If all of the above has been tried...uninstall the printer and download the newest drivers from EPSON and re-install the printer. Good luck Tim
Posted on Feb 04, 2007
Printer has started to slow down to 6-8 minutes to print one photo
Hi Sally. There could be a number of reasons for that happening but here are the most likely causes and their solution. Check the setting for the type of paper and the quality for the printer to use plus the PPI of the image file itself.
Taking the last first, have you changed any settings in your camera - meaning have you perhaps changed the quality to use from say Medium to High? That could change the PPI /Pixels Per Inch) for the image which means a larger files size for the same size image as previously, which in itself means more information for the printer to process as it prints each photo.
When you select to Print - open the PROPERTIES dialogue area and check the settings - for example were you perhaps using the Text & Image, Photo or Best Photo (may be slightly different - I cannot be more specific as you have not mentioned whick model you have but you should be able to see what I mean). Best Photo will take longer than Photo, which itself will take longer than the T&I setting.
Then there is the paper type. Different choices can change how long it takes - so for the least quality, the Plain Paper setting will be the fastest (and could give a decent print, believe it or not IF better paper is actually used).
To permanently change the Default (the one always used) for the printer, go into Control Panel and find the Printers section, right click on the printer icon and select Properties. You can then set what you would like to use every time as your standard setting (the Default) - which you can change for each print job at the time of printing, using the printers Properties facility - which then only applies for that time as the printer, for all future work, will revert back to the Default - so you would change per print job if you have different requirements - for example - even the normal size paper, which is generally always defaulted from installation to A4.
Hope those give you some areas to explore to see where your change has occurred - as it will be due some change along the line - the printer will not, of its own accord, go slower - there has to be a reason for that and it is most likely one or more of the settings shown above.
Sep 16, 2015 | Epson Stylus Photo 810 InkJet Printer
Does not print red on regular copy paper Does print red on 4 x 6 photo paper
Check ur printer settings. Might be set to print on photo paper.change settings to normal paper. If all else fails. Uninstall and reinstal printer software.
Nov 01, 2011 | HP Photosmart 3210 Printer
My mfc 495cw printer isnt printing photos
Check the printer settings on your computer.If you print a photo on photo paper you have to select photo paper on the printer media type settings.
Dec 05, 2009 | Brother Office Equipment & Supplies
I need your help please.
Make sure you are using the paper that come under the specifications of the printer (102 x 153 mm (4 x 6 inches) for a Photo Paper). Though you are using the correct paper and you are getting the same message, then just set the paper type as "Plain" and try to print from the photo paper. It works in most of the cases
gud luck
Oct 24, 2008 | HP PSC 1315 All-In-One InkJet Printer
Ink Color Issues
Did you change any of the configurations on your printer. Most photo printers have color settings that are media dependent. It sounds like you might have it set to print on regular paper but not on photo paper. There are a lot of settings that you can accidentally change on a printer so I would suggest uninstalling the printer then reinstalling it and see if that is the issue.
Sep 11, 2008 | HP Photosmart 3210 Printer
Samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Jul 14, 2008 | Samsung CLP 300 Laser Printer
Sticky photo printing and poor quality
Sep 10, 2007 | Dell 924 All-in-One InkJet Printer
FD73 Photo Quality
I'm guessing, cause i own a F505 and not a FD73......but, I dont even see a use for the F505 "standard" quality setting. It will stay on "FINE" quality always. I've got a HP 882c and it prints just fine. I use HP premium photo paper and the printer setting BEST. Are you using photo paper? Regular paper will bleed the colors around. Take some pictures on FINE and print them out on photo paper w/ printer BEST and compare.
Sep 11, 2005 | Sony Mavica MVC-FD73 Digital Camera
I'm getting really confused with the resolution stuff
The C4000 is a 4 megapixel camera and can produce photos that should produce very nice 8 x 10 photos. 11 x 14 prints may be pushing it a bit. Your cameras should be set for 2048 x 1536 and the .jpg compression should be set to "Super High". Better yet, that camera can produce TIFF format. For photos you plan to print, use the TIFF format. The other half of this process is the printer. Most inkjet printers have a number of settings. Make sure that it is set for photo paper and be sure to use glossy photo paper. If you can print a 8 x 10 print in less than a minute, your printer is not set right. If it seems like it is taking forever, it is set right. .................... Using Photoshop Elements 2: Open your photo into Elements. Click Image, Resize, Image Size Remove the checkmark from "Resample Image" Change resolution to 300. Notice that the width height is about 5 x 7 inches. So if you print that photo at 300 dpi (dots per inch), you will get an outstanding 5 x 7 print. Most inkjet printers produce their very best outputs at 300 dpi. At 200 dpi, the image is still quite good. When you get below 150, you will start to see changes in quality. Now set the Resolution to 200 dpi and notice that the output size has changed to about 8 x 10 inches. Now check to see how it will look on paper. click OK. Click File, Print Preview You can verify that the photo fits on the paper and that the paper is correct (horizontal/vertical). Now print the photo. The next window that opens should let you get to your printer properties and you can verify that you have the printer set for it best settings and that paper is set to photo paper.
Sep 06, 2005 | Olympus Camedia C-4000 Zoom Digital Camera
Epson Stylus Photo 925 InkJet Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
