My wlan light has come on red and its never done it b4 allways been clear
  • 302 Answers
Its a security problem, access your router and check out your security settings
Posted on Dec 06, 2008
  • Big Poppa Marv
    Big Poppa Marv Dec 06, 2008
    its a security problem, access your router admin screen and check your security settings
My subwoofer keep showing a red light when i switch it on, could it be a fuse fault?
Probably not. The red light indicate idle mode. The woofer might have an auto-sense switch. When activated the subwoofer turns on when an audio signal is sensed at the subwoofer input.
Such switches often have three positions:
Idle (Somewhat off, but not quite)
Auto (Turns on the woofer when audio signal is detected)
Allways on. (The woofer is allways on - you might hear humm in the woofer when no audio signal is present)
Apr 24, 2016 | Audio Players & Recorders
Cloudy water that stinks
1st priory is to save the fish !! move them to a new container consisting of half old water and half new water (declorinated) along with a small air bubbler !! this should help your fish to recover (don't use soap to clean out container it is toxic to fish) moist table salt is best to use for a cleaning agent and rinse well b4 putting fish inside
then ck to see if your aquarium is pumping water thru the filter and falling back into tank ( replace all the water in the tank 1st with two rinses ) make needed repairs to pump and or filter assembly (New filter cartridge) new pump impellers and cartridges are available for purchase for your aquarium from vendors that sell aquariums and allways ck the outlet the pump is plugging in b4 blaming a pump fail with a known good table light set to "On" they do go off once and an a while
verify that water chemistry is ok b4 retuning fish to tank and observe fish for strange behavior for next several hours ( upside down swimming, laying sideways )
Jan 02, 2014 | Marineland Filtration Eclipse Seamless...
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
I broke my wlan switch on my psp 3000 and now i cant use internet access for any thing, help?
You can replace the switch else you just have to open ur psp and in the left corner you will be able to see a switch u just have to push it up.Now the wlan switch will allways be on and u could use it whenever u want... The best thing is to give it for a service...
Warning:Opening ur psp will cut ur garuntee....
Feb 11, 2011 | Sony PSP-3000 Black Console
Hello, i resetted a dlink dwl 2000AP wirrels acces point, and now afther set up, the wlan led doesn't light up any more
If the WLAN light wont come, first thing that you can try here is to reset the unit again, by pressing the reset button for 10 seconds to correct the problem and once you're done resetting the unit unplug power for 10 seconds and then check if the wlan light is back....
Dec 01, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
My hp 1320 printer warning light & green light allways on
please you buy a new original cartridge not use refill or third party or remanufacture cartridge because this cartridge have a image chip hp branded so allways light red blinking
Nov 13, 2009 | HP LaserJet 1320 Printer
I have a compaq presario c700 that has the WLAN disabled and it wont turn on i need help getting it on to find my routor it was working 2days ago now its not any help i have compaq c795tu laptop and my...
in very laptop there is a switch button that determines if your wlan is on or off. Try finding it and switch it to On. I hope this will help you,, if it doesnt work let me know.
May 30, 2009 | Compaq Presario 700 470024-192 Notebook
the starter motor is on the rear side of engine nearest bulkhead and is connected to the engine where it connects to g/box clutch housing by three bolts b4 you tamper disconnect the earth lead from battery also if location is not clear in above ? follow the positive +red lead to where it connects on engine this will be the starter solenoid part of motor hope this helps ps to remove starter is best done and more accessable from below
Dec 27, 2008 | 2001 Ford Escort ZX2
Thompson speedtouch ST585 RED LIGHT ON WLAN
When the red WLAN light is flashing in conjuction with the internet light it just means a wireless computer is connected to the internet through the router
However I had a problem with the internet light flashing red and it required the router to be reconfigured
Oct 20, 2008 | Computers & Internet
No lights(lits)on WLAN-No acces from the computer
WLAN light will give you the status of your wireless connection. If WLAN light is off, it might be a possibility that wireless has been turned off or worse is the device had stopped broadcasting a wireless signal. you may try using to get into the setup page of the device to check if wireless has been disabled.
Aug 29, 2008 | Trendware TEW-630APB (TEW630APB)
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
