Question about Kyocera FS-2000D Laser Printer
Black line on prints from Kyocera fs2000d
Black line on rhs of printed sheets from KYOCERA FS2000D
is there any mtnc that can be done to the drum & how do I remove drum to send to the KYOCERA MITA support?
  • Anonymous Mar 14, 2014
    Vertical line
Remove the drum by opening the LHS of the printer & removing the toner waste bottle, then depress the grey button on the drum assembly & firmly pull the assembly out. Best done in a darkish room as the drum is light sensitive.
The black line couldn't be fixed as it is caused by a scratch less that 2mm long on the drum. Ether a new drun at £299 or a new printer ar £245..
Posted on Dec 04, 2008
Tray 2 wont print kyocera fs2000d
you have to go into the print driver settings and tell the driver that tray 2 is installed. kyocera support website can help with instructions for print drivers
Jun 28, 2013 | Kyocera FS2000DN Laser Printer
Error code 7410:0167274 on a Kyocera FS2000D, what does this mean?
The 7410 indicates a drum error (see below) the 0163053 is the number of prints made by the printer. The drum was most likely knocked loose when installing toner.
Drum unit non- installing error -
The drum unit is not installed or not installed properly.
Detaching and refitting the developer unit Procedure
1. Open the top cover.
2. Open the MP tray.
3. Remove the developer unit.
4. Check or replace the developer unit and refit all the removed parts.
Detaching and refitting the drum unit
1. Remove the developer unit.
2. Open the left side cover and then remove the waste toner box.
3. Unlock the drum unit lock and then remove the drum unit.
4. Check or replace the drum unit and refit all the removed parts.
I hope this is helpful,
Shawn
Jun 10, 2011 | Kyocera FS-2000D Laser Printer
Dear...i have kyocera printer FS2000D and error code 7410:233769... Can somebady give me some advice what can i do....Thanks in advance
installed properly.
The drum PWB EEPROM does not communicate
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Oct 05, 2010 | Kyocera FS-2000D Laser Printer
Kyocera FS2000D. Paper jam reported occassionally
this is problem with sensor you have to check all the sensors like
registration sensor
duplex jam sensor
paper exit sensor
face down tray paper full sensor........
easy way to solve this problem is remove Durmunit and toner box and rear unit then clean it useing a blower and refix all the componet and try...........
Oct 06, 2009 | Kyocera FS2000DN Laser Printer
Call service 7410:0100539 on a Kyocera fs2000d
I have heard that 7410 is a standard code meaning the drum is out of position. Seat the drum correctly and away you go.
David
www.copycare.net
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Kyocer FS2000D hasjust been cleaned (dusted) inside and now am getting service code 7410:0150815 Any suggestions?
The drum could be problem - not inserted correctly or contact problem. If I'm not mistakened the numbers after the colon is the page count when the problem is detected.
Dec 17, 2008 | Kyocera FS-2000D Laser Printer
Looking for the part number of a Kyocera TK312 FS2000D printer. Any ideas on what that part number is ?
Dear,
This is (TK312) Black Toner Cartridge ,which is used in Kyocera FS2000D Printer.
Be Happy Always
Regards
Dec 03, 2008 | Kyocera Office Equipment & Supplies
Will not print
Go to the Start menu and select "printers & Faxes". Ensure that the FS2000 is set as your default printer (right click on icon and select as default). If you still cannot print you will need to reinstall the printer drivers from disk or download from the Kyocera website.
Aug 07, 2008 | Kyocera FS-2000D Laser Printer
Kyocera FS-2000D Laser Printer Logo
676 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
