My Western Digital My Home external drive is not showing in Finder. I've recently had a power outage and since then it stopped showing in Finder. I've plugged the chords in and out again and pushed the on/off switch a few times but nothing worked. The green light is still showing on the power 'brick'.
  • erahi Dec 05, 2008
    thnx for responding. i managed to get it working. Im not sure why it wasnt switching on for weeks, but it began to work again once i did this: - Plug the FW chord to my computer, then put my computer to sleep,  then plugged the drive into powerpoint, then woke my computer from sleep. After those steps in that exact order, it seemed to work again :)
    President:
  • 2,992 Answers
It's possible something was damaged on the interface board inside the case, or on the drive itself. If you listen to the drive and it sounds like it's spinning up normally when you turn on the power, it's probably the board. I haven't had it happen yet on my WD external drives (I have two), but I have seen 3 Maxtor brand external drives with that problem. The drive itself was fine when put into another external case.
Posted on Dec 03, 2008
My external hard drive (wd) not showing the datas, but its occupied space.. how to get my datas from this...?
may be its hidden.
Select show all hidden folders in ur computer
still not showing then the virus have affected it u cant get back data
Jan 31, 2013 | Western Digital Elements powered by WD 320...
Have brought a new external hard drive for my laptop, i've plugged it in and the system sain it was installed successfully but its not showing in my computer have tryed restarting a few times, i've...
If you are using a usb hub disconnect it completely and try connecting your Western Digital directly to a usb port on your laptop. If that doesn't work try booting into safe mode and see if it shows up then. If it works in safe mode a recent update to your virus program or another program could be blocking it. Hope I was of some help , Thanks for using FixYa
May 11, 2011 | Western Digital My Book Essential Edition...
Access denied to my western digital external hard drive from my new laptop
I am having the same problem..computer is showing that its there but says its 'unaccessable'...access denied. a few days ago, my computer got turned off due to a power outage. when I turned it back on, the mybook was deleting itself.....It worried me, and it wasn't showing up on my computer for a little bit. eventually it was back on and had backed itself up. Now again after another power outage, it deleted itself and now its just at a stage where its saying access denied. sorry, I don't have a solution, I'm just like you, looking for answers. I had so much data on this, please don't tell me that I've lost it!
Jun 10, 2010 | Western Digital My Book Essential Edition...
External Hard drive files will not show up on dvd player
run a disk check on drive, as for files under explorer view, arrange icons by:
Feb 04, 2010 | Western Digital WD Passport 250GB Portable...
Is the Western Digital external drive working?
1. Restart your Mac with the drive plugged in. 2. Use Disk Utility (/Applications/Utilities/Disk Utility) to look for the drive. 3. If it isn't mounted, select the disk in Disk Utility, select the Disk First Aid tab, and click Repair Disk.
4. Look in the Finder Preferences and make sure that you haven't disabled the display of disk icons on the desktop.
Oct 16, 2009 | Western Digital Passport 320GB External...
WD 500GB MyBook stopped mounting on MacBook Pro
Have you tried it in another computer? I think these kind of problems can sometimes be caused by USB voltage problems, especially if your MBP has an old battery (I believe the battery is used as a power buffer to keep size of transformer down). If that doesn't work, see if you can find someone with the same HDD power supply and try switching that over. Failing that it's data recovery, you may be able to do this yourself by switching the actual hard drive into a new enclosure.
Aug 23, 2009 | Western Digital 500GB My Book Pro-External...
Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
Jan 26, 2009 | Western Digital My Book Essential Edition...
Restore Pictures
right click on the image..should tell you what they are..in meantime, I recommend Picasa from google.com, which is a nice little photo product manager.
Oct 11, 2008 | Western Digital My Book Home Edition 500...
Computers & Internet Logo
David Payne
David Payne
