Question about LG GSA-E10L (8801031212552) DVD±RW Dual Layer Burner
Usb not reconised the dvd rrecordert lg GSA-E10L
My usb port not reconised my external recorder
  • 3 Answers
Download latest driver u can google for the latest driver
Posted on Jan 23, 2009
External DVD Model GSA-E10L Can't read DVD-RAM disc. it's need update driver or not? now,LG GSA-E10L Firmware LE07.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
check the leads that attach to this external dvd you might have to physically unplug the leads for this dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 05, 2011 | LG GSA-E10L (8801031212552) DVD±RW Dual...
I cant use my lg external dvd drive on linux mint 7.
hi mcasey82,
Yes lg external dvd drive would work with just about any latest linux distribution, if your user account is a member of the plugdev linux groupthe drive will automatically appear on the desktop after you plug the drive from the usb slot
you can verify the plugdev group members by issuing a command cat /etc/groups from the command terminal
user@localhost# cat /etc/groups | grep plugdev
if your current username is not a member, you add by issuing a usermod command
user@localhost# usermod -g plugdev username
Aug 03, 2009 | LG GSA-E10L (8801031212552) DVD±RW Dual...
LG GSA E 40 L External dvd writer not recognised
you may be having conflicts with usb devices. try temporarily removing all unnecessary devices from the usb ports. unplug and then plug the drive back in. you could try another port. if all ports are in use, then unplug another device, like the mouse and plug in to that port, then plug the mouse into the writers port. i had a similar problem with a wireless usb lan that stopped another device from being recognised. when i removed the lan and replugged the unrecognised device, windows recognised it. i obviously had to use the wireless lan, so i swapped that with the mouse and it worked.
Jul 19, 2009 | LG GSA-E40L Burner
Will not burn
try to clean the lense with a special brush cd.ussualy this works
bye
Feb 03, 2008 | LG GSA-E10L (8801031212552) DVD±RW Dual...
LG GSA-E10L DVD±RW Dual Layer
Try reseating your IDE cables. or Assuming you have powered down and restarted and then click start button\control panel\system\hardware tab\device manager and see if there are any yellow/red flags that might give you some information.
If all else fails go to the cd drive in device manager and uninstall the driver and follow directions, choose automatic install when it gets there. Then do the same with the cd/dvd and see if things work.
Jan 24, 2008 | LG GSA-E10L (8801031212552) DVD±RW Dual...
Lost Disk
Try the manufacturers web site for support and downloads.
http://us.lge.com/support/download/search.jhtml
Dec 21, 2007 | LG GSA-E10L (8801031212552) DVD±RW Dual...
Windows vista compatible
TRY THE MANUFACTURES WEB SITE..
WINDOWS USUALLY SHIPS WITH DEFAULT DRIVERS THAT SHOULD WORK FOR MOST DEVICES (MEDIA)
Nov 10, 2007 | LG GSA-E10L (8801031212552) DVD±RW Dual...
LG GSA-E10L (8801031212552) DVD±RW Dual Layer Burner Logo
305 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
