Question about Nikon D50 Digital Camera
D50 won't take a picture!
When I press the shutter release button, shutter remains open and the LCD on the top displays a blinking 'ERR' message and when I press it again it closes the shutter but does not capture anything. I had dropped my camera few days back from about 1 feet, don't know if that caused the problem :( Everything else in the camera seems to work as it should, camera meters properly, focus mechanism works, camera review is just fine! Any helps!! Thanks!
  • Vikas Garg Feb 11, 2007
    Thanks for the suggestion, but I wish it was that simple a problem!
    I have tried doing that!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Posted on Feb 25, 2008
I experienced this problem yesterday at an unfortunate time. I was halfway up a mountain and the trees were covered in the heaviest frost I've seen. I missed capturing some very nice pictures.
My D50 is 2 years old. The battery was low but still functioning fine. When I got back to my hotel, I charged the battery fully, and the problem still appeared.
Today, I met someone who suggested using the reset button on the bottom of the camera. It didn't help. Then he took off the lens, turned the camera to manual mode, and pressed the shutter release. The mirror came up and you could see that the shutter was open. When the shutter release was pressed again, the shutter closed and the mirror went down. No picture was recorded.
The shutter release was pressed several times and then just held down. The camera was in continuous mode, and it just started to work properly and record to the SD card.
I don't know what solved the problem, but one other post I've seen when searching on this problem indicated that switching to manual mode cleared it up.
Posted on Feb 17, 2008
Aperture ring must be locked
Posted on May 07, 2008
Had this problem ans it was returned toNikon. Not sure what they did but I know they cleaned it. Try sending it back...
Posted on May 02, 2007
Try charging up your battery....
Posted on Feb 11, 2007
Err on top of display on camera
Unfortunately, this probably won't be a good situation. Most of the time the ERR(or) message you're getting shows when there's an internal problem, and most likely a shutter error. Not an uncommon problem with the older consumer models like D40, D50, etc.
Dec 27, 2013 | Nikon D50 Digital Camera
I get "Err" on the
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jan 25, 2011 | Nikon D50 Digital Camera
I have a D80 since 2 years and since last 1 week have been getting the 'Err' message. Initially, after referring to the manual & pressing the shutter release button, the camera responded only ONCE. ...
Hi sandeepbhat2, On page 129 of the D80 manual is the factory reset switch. Look on the left side of the camera there is the terminal cover, inside below the USB connector is a small reset button. Give that a try. If still it does not work you should call Nikon.
Jun 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
Trying to figure out how to use the timer on my Nikon Coolpix S570
Press the self-timer button (left of OK).
Press up or down to choose either two second or ten second delay.
Frame the picture and press the shutter release halfway to set focus and exposure.
Press the shutter button the rest of the way. The self-timer starts, the remaining number of seconds shows on the display, and the self-timer lamp blinks.
After the picture is taken, the self-timer reverts to OFF.
To cancel the self-timer, press the shutter release button again.
Fuller details can be found in the manual under "Taking Pictures with the Self-timer."
Jan 15, 2010 | Nikon Cameras
My camera has the err 99 on the screen and won't take pictures anymore
The Canon Error 99 occurs when there is a contact issue between a lens and the body of the camera. it can also be caused by a defective battery, defective storage card you can try to take the battery out and put it back in.if the problem still persists you can run a firmware update.
Canon have now created firmware numbered 1.0.3 that aims to tackle the Err99 message.
Firmware 1.0.3
1. Corrects a phenomenon in which an image becomes overexposed when C.Fn.II-3 Highlight tone priority is set to “1′ together with other camera settings. (This correction has already been incorporated in the Version 1.0.2 and later firmware.
2. Corrects a rare phenomenon in which “busy” blinks on the camera’s display panel and the shutter cannot be released due to the timing of battery installation.
3. Corrects a rare phenomenon in which “Err 99′ appears on the camera’s display panel and LCD monitor and the shutter cannot be released due to the timing of pressing the shutter button.
Jan 07, 2010 | Canon Rebel XT Digital Camera
Error blink in place of shutter indicator
I AM SAGHA REPAIRER FROM MUMBAI I THINK THERE ARE PLENTY OF REASONS SHOWING ERR ON TOP DISPLAY BUT IF ERR IS SHOWING JUST BY TOUCHING THE SHUTTER RELEASE BUTTON THEN THE MAIN BOARD IS DEFECTIVE.IF ANY MECHANICAL ACTION OCCURS AFTER PRESSING SHUTTER RELEASE BUTTON AND THEN ERR APPEARS THEN THE FAULT COULD BE OF SHUTTER & APERTURE BLOCK.I THINK ALL THESE SOLUTIONS ARE FOR EXPERTS AND NOT FOR GENERAL USERS IF ANYBODY FINDS THEM USEFUL LET ME KNOW & ALL THESE ARE BASED ON MY OBSERVATION ABOUT FAULTY CAMERAS.
May 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
"Err" appear in the viewfinder and LCD display
i have a Orite Mv 3115-Real Dv Mpeg4Vga resolution 30 FPS Digital Veidio Camera. no the problem that the battery of my camera down and i sent that with my friend to bay a new for me unfortunatly he miss that on travel so i need to fins a new battery for that
i hope sir you can healp me to find one and a charger too
Feb 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Shutter
I had the same problem but replaced the lens with a different lens and it worked just fine.
Aug 27, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera Logo
737 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
