Question about Zalman Tech Computers & Internet
Cpu fan not running fast enough
I recently bought this product:
Zalman CNPS7700-AlCu Oem pack for Intel lga775 : aluminum+copper FHS + 120mm Fan : 1200/2200rpm , double ball bearing , noise 18/27db - for intel Lga775
along with a gpu cooler. The gpu fan is running fine, but my cpu is running at 60-65C when my pc is idling, even if I take the cover off it remains so hot. I have checked all the wires, I can't find any obstructing the fan itself upon the cpu. I was wondering if this is normal or if there is somewhere I can adjust the cpu fan speed that i'm not aware of.
I would appretiate any help.
Kind regards,
    Problem Solver:
  • 17 Answers
This will depend on the motherboard you are using.
however, you need to make sure that the CPU fan lead is plugged into the correct plug on the motherboard... for example, I have an Intel 975xbx motherboard and it has 4 fan plugs, but only one of those is for the CPU. The others are for front/rear/top fans. If the CPU fan is plugged into one of the secondary ports, the CPU fan wont speed up correctly.
Also, some BIOS settings in the motherboard allow you to enable or disable automatic fan speed adjustment, and also set the temperature points.
Posted on Dec 09, 2008
Driver lga775
Drivers for Intel products can be downloaded from
Perhaps you need motherboard drivers, in which case go to your system manufacturer's website, motherboard manufacturer's website.
You will need to know what operating system you are using.
Oct 23, 2013 | Intel Celeron D 356 3.33GHz 533MHz 512K...
What mother board should is best for use on this video editing,engineering,and games with better graphics and can also work for more than 18 hours?
The best computer mainboard, would be either an AMD AM3 mainboard made by ASUS. For example ASUS Crosshair IV Formula or ASUS M4A88TD-V EVO/USB3. Or an Intel computer mainboard. ASUS Socket 1156/1155/1366.
Your Pentium Dual-Core E2180 2.0Ghz on the LGA775 socket is not good for Games or video.
The best thing to do is to purchase a new computer system.
Use either AMD Phenom 2 or Intel I5 or I7.
Use a good mainboard as above.
Use a good Graphics card, Nvidia 400 series.
Keep all the components running cool with a case that you like and has place for lots of 120mm or 140mm fans.
Use DDR3 RAM 1333MHz or higher.
Use Cooler Master or Corsair Power Supply.
If however you are wanting a good mainboard to be used with your Pentium Dual-Core E2180 2.0Ghz on the LGA775 socket then click here.
ASUS is very good, all these mainboard on the LGA775 socket are good, choose one that looks good to you and one that you can afford.
Thanking you kindly
Feb 02, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Will Intel 965 Extreme Edition / 3.73 GHz work with this board - ECS P43T-A2 - cpu fan comes on but no video
Sorry, but the Intel Pentium 4 Extreme Edition 3.73GHz CPU is not supported.
You need to check out the supported CPU list for the P43T-A2.
Click on the link provided;
Main web site for the ECS P43T-A2 MB;
It will support, Intel Core 2 Extreme QX9650 (C0),
3.0GHz, (2x6MB,1333 MHz,LGA775)
Hope you find this helpful!
Nov 10, 2009 | EliteGroup ECS P43T-A2 Intel P43...
Where can I get a new fan?
Find to the nearest computer hardware shop Zalman VF700-AlCu vga VF700-AlCu cooler, buy it and mount it.
Oct 13, 2009 | ASUS V8420/TD Graphic Card
Cpu cooling
The ZALMAN CNPS9700 is the best air cooler on the market.It looks cool and is quite easy to install. I have one in my box and I have 34 degrees with an Intel Quad core running 1 Gigahertz over stock.
Nov 01, 2008 | Computers & Internet
Suitable CPU air cooler
I suppose you have done your homework as to if u really *need* to buy a new cooler. Is ur CPU getting HOT? what temperatures does it run at? Your choice of cooler depends on what you plan to do with it. Do you plan to overclock your system? I would suggest a Coolermaster stock copper cooling system. Zalman is also good but expensive. But as i said depends on what u wanna do with the system and if u really need that extra cooling if you dont plan to overclock your system.
Dec 24, 2007 | EliteGroup ECS P4M800-M Socket...
ASUS cpu fan required
CPU fan is supplied with the processor it self you need to contact your processor company
it you are talking abt the Casing fan then just get an ordinary casing from from a hardware shop
Dec 13, 2007 | Zalman Tech Zalman North Bridge Chipset...
Video Problems.
well, I suppose it could be the motherboard, though I doubt it. I wonder did you check; the board, processor and graphics card on against the vista HCL (Hardware Compatability List) you should be able to find it on microsofts website. Unfortunately being a 64 bit OS, and considering how new it is, very few devices, software and drivers are actually designed to work on vista yet. I hear alot of complaints about vista not working properly. thruth is vista isn't the problem, other companies didn't keep up. anyway, I hope you can fix it. and honestly I hope it isn't a hardware compatibility issue. Either way Good Luck
Jun 18, 2007 | Intel D946GZIS Motherboard
Computers & Internet Logo
551 people viewed this question
Top Zalman Tech Computers & Internet Experts
J D Wright
Bill Boyd
Are you a Zalman Tech Computer and Internet Expert? Answer questions, earn points and help others
