Question about Whirlpool Washing Machines
Doesnt fill with water - Whirlpool Washing Machines
  • Whirlpool Master
  • 3,463 Answers
I assume you have the water turned on?.
To make sure that you have water to the m/c, try loosening the hose(s) at the rear of the m/c, there should be pressure there.
If o/k, make sure door is shut securely.
Hope this helps.
Posted on Dec 03, 2008
Water doesnt stop when filling washing machine
There should be a "fill control" on the panel of the achine that lets you set the fill limit for wash loads ranging from small to large. Obviously, your fill control is not working
Oct 09, 2012 | Washing Machines
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
The tank doesnt fill up by itself after flushing. I have to manually lift the bar to start water. Then when the water is running the floating thing doesnt rise and the water empties again.
The floating thing is most likely filled with water, if the unit is old replace everything inside the tank you will be better off if you do not wish to do that just replace the floaty thing. Good Luck....
Nov 15, 2010 | Home
The water is on but the water doesnt fill the washer. the spin cycle works how do i get the water to fill the washer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | Maytag MAV8557 Top Load Washer
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Water level doesnt work. The drive belt was worn out so I replaced this now when I fill the machine the water just keeps on filling and overflows as it doesnt stop the water.
Either you have a hole in the pressure hose or one of the ends came off. The last thing is the pressure switch needs replaced.
Aug 12, 2009 | Washing Machines
Ice maker water line doesnt shut off
If the icemaker did not stop right in the spot where the water fills the tray, without completing the cycle, you have an icemaker problem, but that is highly unlikely. More likely is that the water fill valve (the part right where the water line hooks onto the refrigerator) will have to be replaced.
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
THE WM DOESNT STOP FILLING UP WATER
It sounds like your water level switch is bad and needs to be replaced. The inlet valve opens and starts filling, and timer operation is suspended until the water level switch operates.
Jan 10, 2009 | Kenmore 24902 Top Load Washer
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
