Question about Acer Aspire 5520-5908 Notebook
Camera is busy
When i try to use my camera (acer 5520) this message comes up but without using at all my camera
  • Magumz Dec 15, 2008
    I have the same problem. My camra says it is busy. I have used it many times, and have not installed anything new on my computer other then the regular Windows Vista Updates.
    I have an Acer Aspire 5920.
  • Jason Edinger May 11, 2010
    Are you using a logitech camera while using Thunderbird?
Why wont my printer let me print off my work
Generally speaking when I see this message I just hit OK and it goes ahead and prints and everything shows up without being cut off - I am in the ink business and my test page shows this message all the time but its not an issue if you press OK and part of ther page is cut off you eitherr need to expand your margins or make the content fit the page
Sep 15, 2014 | HP Photosmart 5520 e-All-in-One -...
I dont get it. i had my acer 5520 swiped and
I have had the same problem with drivers. In every case I eventually found that I was trying to load the wrong driver.
Are you using Vista 64bit version?
Is the driver you need in a sub.directory of the main folder?
Download the drivers again to make sure they were not corrupted the first time.
Oct 31, 2009 | Acer Aspire 5520-5908 Notebook
Bluetooth on acer 5520
some do and some dont, blue tooth is optional on most laptops.
the best way to find out is to try to install the blue tooth driver from the acer web site.. it will be able to tell you if it is installed.
May 26, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520 Vista Cannot Read Disc no matter what
You probably need to swap it out, lasers and spindle motors often go bad.
Get a new drive off ebay (you can even upgrade to lightscribe for like 10$ more at this point): http://shop.ebay.com/items/?_nkw=Acer+Aspire+5520+cd+drive
Looks like you need to take the keyboard off and unscrew the screw holding the cd-drive in.
Mar 25, 2009 | Acer Aspire 5520-5156 Laptop
Acer aspire 5520-5116
Please check the ports if not grounded to each ports. or use the front panel ports if there is. If still the same then you have to check for repair the ports.
may this help.
melnavz
Feb 25, 2009 | Acer Computers & Internet
Acer Crystal Eye Webcam and MSN Messenger
Make sure you are not running the Desktop Icon program first. The camera can only be used by one program at a time.
Now login to Messenger, and click
Tools > Audio and Video Setup, and click Next past the audio settings, and choose USB Video Device from the list. It should work after a couple of seconds. If that doesn't work, try the other device drivers from the list, waiting a couple of seconds each time, until you can see some output in the window. Then apply and you're ready to go.
It's the same deal with Skype, except it's in
Tools > Options > Audio Settings.
Hope this helps
Chris (ziraffa)
Jan 16, 2009 | Acer Aspire 5520-5908 Notebook
Acer usb cam makfunctioning
try consulting the mfg for updated drivers. Try removing the usb port it's using and letting it redetect the port, also see if there is special software that comes with the usb camera and reinstall that. If all fails reinstall windows.
Nov 19, 2008 | Acer Aspire 5100 Notebook
Microsoft
it comes with a demo version , so uninstall the program and if you have a cd of MS - Office then install the complete version of
MS- Office or go to some tech. and have it done
Apr 25, 2008 | Acer TravelMate 5520 Notebook
well fist the size that it is says is creating the error is interesting. My guess is that the fault is because the picture you are trying to access is actually a GIF. If this is the case many camera software and even some of the graphic software will not read it. Try opening that picture in internet explorer and see what happens. To remove the fault what i would do is erase the picture or move it to another part of your hard drive. That way when you start the camera it will not be looking for that picture but another JPEG.
Sep 17, 2007 | Acer Aspire 3610 Notebook
Acer Aspire 5520-5908 Notebook Logo
278 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
