Question about Acer Aspire 5610-4648 Notebook
Hello i got aspire 6920 problem about built in web cam.. i check the driver from the device manager i was install and work properly i can use webcam in yahoo messenger but,when i click crystal eye to use as a camera to take picture it say webcam not found any solution on this guys
Activating web cam
Check from your device manager that webcam drivers are properly installed. also check that webcam is not disabled.
Feb 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
My acer aspire 4720 cam not working
first check you have installed all the web cam driver came with your notebook than check the control panel> device manager > imaging devices acer crystal eye web cam if there is a yellow ! . then re install the driver...
Jul 19, 2009 | Acer Aspire 4720 Notebook
Hi, i have problem in my web cam the model unit is a4tech pk-635m, the reason is i download a web cam effect for free then after downloading it works, then when i use my web cam on the next day it didn't...
goto mycomputer,right click select properties,hardare,device manager, right click image & scanners,right click uninstall, goto action menu, select scan for hardware chages.
wait and see... hope it will detect again and work good.
Jul 04, 2009 | Acer Aspire 6920 Notebook PC
Web cam
check if the driver is properly installed go to device manager and check if it has a yellow question mark around which means the driver isn't properly installed if so, find the appropriate driver online
Nov 19, 2008 | Toshiba Satellite A135-S2276 Notebook
Acer aspire 5612zwlmi web cam and mouse pad
Mouse pad jumping can be common symptom of Synaptics pads (is it Synaptics?) - look for driver and install it.
Also, try switching it on from off and do NOT touch the pad for several minutes.
Common symptom when people just use very light pressure on mouse pad within first few minutes. Latest driver should fix.
also try pressing whole palm down on touchpad for several seconds - this can reset the software on some touchpads.
As for webcam, disconnect it, uninstall drivers, re-install drivers and then re-connect it. If it is built in then go to Device Manager - Hardware and find the device - click on uninstall driver - then re-install the driver.
Jul 22, 2008 | Acer Aspire 5610-4648 Notebook
Problem with Acer Orbicam aspire 5102WLMi not working
you have chosen the wrong driver, go to the link below and choose orbicam (logitech) not the Bison one
Apr 15, 2008 | Acer Aspire 5102WLMi Notebook
Web cam problem
I think ur laptop webcam driver not installed properly.If ur laptop have windows vista operating system then do these steps.
Goto Start - Programs - Recovery Manager - Recovery Manager.In that recovery manager,click on next.Its shows the Software reinstallation page.Click on next button two times.Its shows the software lists.Select the webcam software and click on next button.After reinstallation completed , u restart laptop and check it.
If ur laptop have windows XP operating system then u uninstall the webcam software through Add/Remove program and restart it.After restarting ,Reinstall the web cam software and check it. If u doesnt have webcam drivers then u go for nearest service centre and install it.
Mar 11, 2008 | Acer Aspire 5630 Notebook
Orbi cam not working
run device manager and removed auknown device driver.. then restart, if you need driver try this web
Mar 11, 2008 | Acer Aspire 5610-4648 Notebook
Acer orbicam won't work
Double check that the sam is installed and enabled in Device Manager.
Click Start Menu
Right Click on My Computer and select Properties
CLick the Hardware tab
Click Device Manager
Now expand the box (click the little + on the left) of imaging devices
If you see your webcam, doulble click on it and look under Device Status and see if it says it's disabled or not functioning properly.
If it is disabled, simply enable it and it should would.
Feb 21, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 5610-4648 Notebook Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
