Question about Maytag MSD2456G Side by Side Refrigerator
Maytag RFGS2325GEK Side by Side
We have recently bought a side by side Maytag, after about 3 weeks the it started leaking water. I found that it was the ice that had been made melting. That was the first sign that the freezer was no longer freezing. It slowly went cold and the fridge compartment was soon to follow. We have since had it replaced by the company but now after 2 days I woke this morning to find the ice melted again.
The technician stated that a compressor or something had blown completly the first time and it was nothing we had done... but 2 fridges in a matter of weeks doing the same thing... its hard not to think it's you??
Any ideas on what could be causing this??
  • 1 more comment
  • kyriakosmum Dec 03, 2008
    There were no power failures or interuptions to the power. The fridge is plugged into the same power point that the old fridge used. Although the old fridge did not do 'ice' it was still a large old fridge.
    So, still confused.....
    Why would a drain getting clogged cause the first fridge to blow up though? I saw the burnt out bit...
    Sadly we can't ask for a different fridge as it seems this Maytag fridge was the only one that would 'fit' in out space that did ice.
    Genius:
  • 1,239 Answers
Hi If the compressor doesn't run, it is likely that the defrost timer is malfunctioning. This part is located near the compressor. To test the defrost timer:
Step 1:
Unplug the refrigerator.
Step 2:
Disconnect the wires from the timer and timer motor. Remove the timer from its brackets by backing out two retaining screws.
Step 3:
Test the defrost timer with a VOM set to the RX1 scale. Clip one probe of the VOM to each defrost timer -- not motor -- wire, and turn the timer control screw shaft until it clicks. If the defrost timer is functioning, the meter will read zero. If the needle jumps, the defrost timer is faulty. Replace it with a new one of the same type.
Step 4:
Connect the new defrost timer the same way the old one was connected.
To check the defrost timer motor, clip one probe of the VOM to each motor wire, setting the scale to RX100. If the meter reads between about 500 and 3,000 ohms, the motor is functioning properly. If the meter reads higher than 3,000 ohms, the timer motor is faulty. Replace it with a new one of the same type. Connect the new motor the same way the old one was connected.
Posted on Dec 03, 2008
  • 1 more comment
  • ABHISHEK.C
    ABHISHEK.C Dec 03, 2008
    The condenser fan is located under the bottom of the refrigerator. During the defrosting cycle, water may run through a small hose into the drain pan and is naturally evaporated. On some refrigerators, the drain hose is rubber instead of metal. This type of hose can become cracked, causing leaks. Examine the hose. If it's damaged, replace it with a new one of the same type. If you spot water on the floor, the drain pan may be tipped on its brackets, or the pan may be cracked or rusted. To eliminate the leak, realign or replace the pan.
  • ABHISHEK.C
    Coolant leaks are identifiable by their acrid smell.
  • ABHISHEK.C
    you can refer these diagrams
    Genius:
  • 1,011 Answers
Sir,
You may need to run something down through your defrost tube to see if something else is clogging it, if that doesn't resolve it, you will need to replace your defrost drain tube parts.
Also do these things...You will have to remove the rear evaporator shroud. The drain system is accessed from the interior freezer compartment; you will see several Phillips screws holding the rear panel to the freezer rear wall. Remove the rear panel and clear the drain system by removing the ice build up and poor boiling water down the drain to melt and residual ice and to assist in removing any debris that may be blocked in the drain system. Once the drain is clear you will notice water flowing down the drain as you poor it in. Please keep in mind that the defrost drain pan located under your Refrigerator may overflow if there is an excess amount of water.
thanks
goodluck
    Master:
  • 505 Answers
Check first to see if your coils need to be vacuumed. If this does not work you may have a bad defrost timer ( causes the freezer to stay in defrost longer than it needs to be and the food will not freeze) You can change this yourself if you are handy and can locate it on the fridge.
If you want parts and schematics for the fridge you can enter your model number here.
Thanks
  • 10,515 Answers
Hey,
First - Its a common issue with Maytag refridgerators......You can View many Comments regarding the same on consumeraffairs.com
Now , Lets move onto the reason.........
Consensation problem...Uhmm ...nice term :)
Ur refrigerator might be in a closed tight room, isnt it ? I would not comment on other refrigerators, However what i have observed the common reasons for this issue for most of the Maytag .
It might be a coincidence....isnt it ? 2 refrigerators.........Lets assume :)
Check the door seal to may sure it is sealing properly. You can wipe it off clean and caot it with some vasiline. Look also inside unit to see if you can see water dripping down from anywhere.
Uhmm Mre steps to eliminate :) buzz me...:)
Take Care.
  • 928 Answers
If you would ask me id say it was a factory defect. 2 NEW refrigerators in 2 Weeks. Normally if enough complaints are received a recall would be given for that product line. id suggest you have them replace it with a different model.
    Scholar:
  • 81 Answers
The power system been checked before the ref operate, its better to replace the power outlets.
and is the power system for your ref is in separate breaker. and size of the wire 5.5mm with separate circuit breaker in 30 Ampere.
how old is your power system. if that in 10 - 20 years then its really matter. the best thing to do first is your power be in standard, bigger wire and in higher ampere rating. and with good grounding system for your safety. at 5.5 power supply the grounding system would be 3.5mm.
  • Alver Clamonte
    Alver Clamonte Dec 03, 2008
    3.5 mm power supply wire would be also enough with grounding system 2.0 mm and in separate circuit breaker with 20 Ampere rating. but 5.5 mm with 30 Ampere rating is best for your ref to operate in good condition.
  • Alver Clamonte
    if you already turn on your ref. try if the compressor is running
    and condenser fan motor is also running and have ample/bigger space for its ventilation's.
    if the ventilation of the condenser if not enough and it only circulate in small area. that would matter.
    because the compressor will not continue to run because relay will always tripped due to compressor overheat.
    Sergeant:
  • 306 Answers
S ur water dispensor leaking??
  • AbdulRahiman S Dec 03, 2008
    Your freezer defrost drain has clogged up on..
    Just take the bottom freezer shelves out so you have plenty of room to work, then defrost the ice in the drain trough, and use a wire or pipe cleaner to run down the drain.
    c tis>>
    http://www.applianceaid.com/frig_leaking...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, what would be recommended/explored would be:
  • test the power at the outlets used by the Maytag;
  • any other kitchen appliance using the same line or circuit breaker;
  • was there anything untoward prior to the fault, power interruptions/fluctuations;
  • if power outages is pretty common, you may need to purchase and install a power on delay device.
If the above initial posting has merit and should you need additional information, pls click on my "Ask Me". Alternately, postback here how things turned up and to explore your additional options or rate this as you see it fit.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 03, 2008
    Hi again and appreciate the direct "Ask Me".
    To my knowledge, most compressors would go bad for very few reasons:
    • old age;
    • no oil;
    • immediate resumption of power after an outage or a momentary fluctuation;
    • failure of the cooling/ventilator fan (if one is present);
    • restricted, poor or no ventilation in the rear of the refrigerator.
    It is to this that most manufacturers warranty their compressors up to five (5) years.
    In
    none of the above is applicable, then it is likely that the units that
    you had were from the same batch that have a manufacturing issue.
    Perhaps the pages here, here and here may shed additional insights.
    Cheers.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
Water on freezer bottom. I have a Maytag refrigerator, side by side, Model MZD2768GEW, seven years old. Recently I have found about 1/3 cup of frozen water on the freezer bottom. It is not comming from...
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | Maytag Freezers
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
Maytag model # MSD2754GR the refrigerator leaks
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilsh
Nov 30, 2009 | Heating & Cooling
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Water flows in cold side of water valve and out hot side valve
It seems unlikely that something went wrong just from moving it unless it got banged up!
It sounds like you may have stripped the hot side.
I'm assuming the water is going in the cold side and out the hot side and out the back.
If this is so and you are happy with just cold water try this:
Go to a Plumbing Store and buy a cap for the leaking intake...if it still leaks you can try soldering the two together!
I hope this was helpful.
Good Luck!
Jan 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag mdb6000awb built-in leaking problem
it can be 3 problems. Most likely one is the seal from the acces apnel is leaking.
Or hinge of door is too lose or door seal.
My bet is on the seal for the acces panel.
HERE is drawing. However seal (#12E) is not drawn in.
You can also order the parts here and have them within about 3 days
Jun 29, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
May 15, 2008 | Maytag MSD2756GES Side by Side...
Maytag washer
3E has something to do with the motor control. Apparently the design of this machine allows a water leak either from the water intake box or down a rubber hose which runs along with the motor wire harness. The water tracks to the harness and motor and shorts the whole mess out. a.k.a. fried motor.
pull the back plate off (3 screws) and look at the motor where the wire harness plugs into it. Notice a bunch of green stuff- that is corrosion from the electrical short circuit causing your problem. See the rust build up on the side rail below the motor (as there will be none on the side adjacent) this is indicative of a water leak.
Our machine started doing this within the first week and we had the "service" people come out and "fix" it, but it appeared they did nothing. When I opened the machine up I discovered the problem when I ohmed out the rotor contacts in the motor wire harness and found it to be open instead of the factory specs of appx 2.5 ohms.
Maytag (now Whirlpool) does not want to send me a new motor and harness because of their bad design. The machine is a sealed unit only 23 months old. Note to all...do not buy Maytag or Whirlpool. That Maytag repair man is sitting on his bum because the company does not care about their consumers and their cheaply made products (sold at high markups).
If you want pictures write me at aboxoffrogs@gmail.com
also in my model I found the troubleshooting guide in the bottom front kick plate. It is a plastic piece you will have to insert a screwdriver into and "pop" off. This will show you how to enter the "secret" trouble shooting codes into the front control panel. And a definition of exactly what 3E means.
Oct 27, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag MSD2456G Side by Side Refrigerator Logo
27 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
