Question about Samsung V25 XVC 2800 Notebook
Blank screen hi when i switch on my laptop i can hear the fan on but my screen is not working its a samsung v25 thanks
  • bnkers77 Feb 02, 2009
    Soz posted this under another prob as I seem to have several things wrong with my treasured V25. Bigger prob is I have a blank screen after opening it up for some cleaning. Now the screen's blank when I start it up. It is working
    as I can hear it booting up etc but nothing on the screen. Have I
    loosened a monitor connection or done more permenant damage?
    HEEELLLPPP! Had my V25 for 4yrs+ and want to carry on using it as got
    new batt/hard drive & RAM all within last year ish. + I like it. :) Don't want to take it apart again in case I inflict more damage...
Might be the VGA connector to the motherboard.
Turn upside-down. Remove screw in the centre marked KBD.
There are 4 screws running along the back. Remove the 2 inner ones.
Lever up the keypad with a small screwdriver - Careful not to disconnect the ribbon underneath.
Undo the 3 screws along the strip above the keyboard and remove the strip.
VGA connector is next to the power button. Check it is pushed down firmly.
NKYG
Posted on Mar 03, 2009
Hi i have a samsung v25 laptop does it come with wireless and if so how do i activate it please i will be very great full thanking you
there is a button to activate it or go to control panel then network connections and then enable wireless lan
Dec 01, 2009 | Samsung V25 CXTD 2000 Notebook
Hi my girlfreinds samsung v25 laptop does not load up it restarts itself all the time how can i do factory setting on it please email me bck
Dear sir
her i think your problem is on operating system(OS) lavel and u need to recover yr os with recover dvd or recover disk whitch provide with yr laptop and if you need to reset factory setting you have to go on bios setup screen
1 start laptop
2 press F10 button
3 then go to last screen ad find " setup defullt opetimeze"
4 then got to save and exti button
simple.. if u need more help please contact feel free.. thianks..
Dec 15, 2008 | Samsung V25 CXTD 2000 Notebook
Samsung v25
Try to diagnose the problem first...
1. Turn it On your Laptop
2. If you have CRT Monitor? connect it to your Laptop if they have screen appears.
3. If they have display your LCD have a problem.
Aug 09, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 fan replacement
It may not be the fan, I have a V25 and it was the motherboard, it wouldnt power the fans anymore when the CPU required it so would crash lots.
If the fans twitch or run for a second or two when you first turn the laptop on then it's the motherboard that is faulty.
Careful with the monitor to motherboard plug as I damaged mine and the screen is now a permanent shade of blue.
Jun 25, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 laptop
Make diagnose this problem...
Try to replace the Hard Disk?
Try to replace the Memory?
Jun 13, 2008 | Samsung V25 XVC 2800 Notebook
Samsung v25
Sounds like a broken solder joint. IF you can solder good you can heat up the solder and it might fix the problem. The happens to CB radio's all of the time.
May 28, 2008 | Computers & Internet
Can't view the screen
most laptops have an option to switch between CRT, CRT&LCD, & LCD... usually you have to hold down the 'fn' button and then press F5 to switch back and forth.
Did you try that? If that doesnt work let me know the model of your laptop and I will try to help you further.
Regards,
-Chester
Jan 11, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Jan 07, 2008 | Samsung V25 CXTD 2000 Notebook
Samsung v25 won't boot up
this is os or motherboard problem, reinstall the os
Nov 05, 2007 | Samsung V25 XVC 2800 Notebook
Samsung V25 XVC 2800 Notebook Logo
305 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
