Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
Cozy Heater will not turn on from thermostat in the morning
I have a Cozy Heater. It is controlled by a remote thermostat. You can turn it up and down fine during the day, but it will not click on by itself the mornings (even if the thermostat is set to a specific temp.) The pilot light stays on, but you have to jump the heater to get it to start. I have replaced the thermostat, but have found that this is not the problem. Could it be some sort of bad connection between the thermostat and the heater?
  • 59 Answers
No more than 20 feet of statr wire allowed and make sure the stat you have is for a millivolt system.
Posted on Oct 22, 2010
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
My older Cozy cf353c counterflow wall heater gas shuts off pilot after it has run a while. I replaced the bad fan switch thermostat[ fan would not run untill changed] but not the other lemit switch . Could...
first have the heat exchanger inspected for a hole or crack, if there is an oval to round adpt. on top of unit or an elbow in vent this can cause the heat exchanger to split open and also cause what you are talking about.
Jan 14, 2010 | Cozy (W352E) Heater
I have a cozy gas furnace that only comes on when you bump it.
Hi loose connection in the heater or sticking fan or gas valve
Jan 09, 2010 | Cozy (W352E) Heater
Heater won't turn off. Wires were troubled
Shut off the gas to the heater. Bad gas valve. Gas should not be leaking from any part of the gas valve.
Oct 21, 2009 | Cozy (W352E) Heater
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
My Cozy heater does not respond on the thermostat control
Make sure you have a stat that is for a millivolt system, if the stat you have has 24v on it wrong one, need to purchase at a heating wholesaler home depot lowes do not carry them.The stat should have mv for millivolts on the box or stat.
Nov 23, 2008 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
223 people viewed this question
Top Cozy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
