Question about HP iPAQ RX3715 Pocket PC
.net compact framework
When i try to run mobilemedia, i get a message saying a newer version of compact framework is required. i look in program files, and no files show. how do i install the files again (apparently erased them)?
    Problem Solver:
  • 15 Answers
This is the newest .NET compact framework.
http://www.microsoft.com/downloads/details.aspx?FamilyID=e3821449-3c6b-42f1-9fd9-0041345b3385&DisplayLang=en
attach pocket pc via activesync, click download, click "start download" if necessary, and then run the downloaded application. Activesync will do the rest.
Posted on Mar 01, 2008
Nero 9. "this feature requires Microsoft .NET
Just download the .NET framework at Microsoft. See link
NET Framework 4 5 or search ".net download Microsoft".
Just run the downloaded upgrade program and you can use Nero 9.
However, for burning cd or dvd you can better use Imgburn, a free and powerful burning package. See: NET Framework 4 5
Sep 17, 2014 | Computers & Internet
Lexmark productivity studio
Hi, in Windows 7 Microsoft.net framework 3 is installed and newer versions can be installed on it. If you try to install an older version, it will block your installation.
1-Try to download it from Microsoft\'s website and install it with administrator account privilege.
2-Go to the control panel, find out if Windows features are on or off. Try to check
Microsoft.net framework and then restart Windows. Then reinstall it.
3-If you have still problems, go to www.microsoft.com and search microsoft dot net framework 2 in windows 7.
kind regards
Apr 17, 2013 | Office Equipment & Supplies
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
My phone is a Samsung Omnia Pro B7320 Windows Mobile 6.1 and I have downloaded Foursquare. Foursquare is downloaded to the phone but the application does not load says This application requires a newer...
Some applications do require a newer version of .NETCF. You see, I have uploaded .NETCF v3.5 for you. I have also uploaded a small application, .Net Configuration. Install both of them on your device, and run '.Net Configuration'. I'll tell you how I configured it on my device, and you decide if it fits your needs: In the 'Device Policy' tab, I selected '3.5.7283' and tapped on 'Apply'. However I know that the mobile calculator doesn't quite like v3.5, for what, in the 'Application Policy' tab, I selected '\Windows\MobileCalculator.exe' , assigned it to '2.0.7045' (my version of the default .NETCF v2;0 - yours might be slightly different) and tapped on 'Apply'. Tapped on 'ok' to leave the application, and restarted my device.
Of course you can do differently: set your 'Device Policy' to v2.0 (as it has ever been) and assign the application, which is issuing errors with v2.0, to v3.5.
Hope it works for you.
Cheers!
Carlos
Jul 03, 2010 | Samsung Omnia Pro B7320 Smartphone
.net framework installed?
You can check by going to the Add/Remove programs within the control panel or it is called Programs in Vista.
Jul 01, 2009 | Microsoft Network Programming for .Net...
.net framework problem
Hi. The downloaded .msi package actually contains a couple of versions of .net (for different kind of processors). If you connect your PDA to your computer (Using ActiveSync for XP or Windows Mobile Device Center for Vista) and run that .msi package, it will automaticly detect your PDA's processor and installs the .net to your device. Hope this helps.
May 19, 2009 | HTC Touch P3450 Smartphone
HP colour laserjet 1600 not recognised by USB port
I believe the problem is related to microsoft .NET Framework. I have researched and there are many posts of incompatibility between .NET Framework and many printers not just 1600. My 1600 stopped working and I traced the problem to upgrade to .NET Framework 3.5 I uninstalled 1600, then uninstalled .NET Framework 3.5 (and 3.0 as well for good measure), reinstalled 1600 and it is working fine now again. You can uninstall .NET versions using Add/Remove programs on the Control Panel. To avoid re-updating, I also turned off Windows automatic updates. I left .NET Framework 2.0. No problems with other programs but the computer did have trouble rebooting the very first time after I uninstalled .NET Framework 3.5 and 3.0. Unknown if that was related to the uninstall or a completely unrelated problem. Anyway if you want to try something less drastic than removing .NET versions, check out this Microsoft link:
http://support.microsoft.com/kb/961118
refers to a printer fix related to .NET. In my experience, the Microsoft fixes never work but you are welcome to try before uninstalling .NET Framework versions.
Jan 16, 2009 | Office Equipment & Supplies
Unable to create database from within VWD 2005 Express
try to complete uninstall .net framework and install it again or get the latest copy of .net framework to install 3.5 latest version already available for download
Dec 01, 2008 | Computers & Internet
My printer will print 1 time then I get run time error
Newer Lexmark printers require the .Net framework be installed for the software to function correctly. Verify requirements by the documentation or during the software install. If need be download the correct version .NET 2 (I believe) from Microsoft's website.
Nov 06, 2008 | Lexmark Office Equipment & Supplies
HP iPAQ RX3715 Pocket PC Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
