Question about RCA P46812BL 46" Rear Projection Television
TV doesn,t turn on
OK my projection tv did not turn on,so I pulled the plug for 5 mins.,plugged it back in and nothing.So I tooked the back cover off located a fuse by the power supply removed it and it look OK.Put the fuse back in and the TV came on.It was about 24 hrs. till the next time I tried it and the same thing it wouldn't start up.So I took the fuse out put it back in and it worked again.Before I left work (approx.10 hrs.after using the TV)I tried the set and it started up.I did this for about 7 days in a row and the TV worked every time.Till the one day I didn't start it before I left for work and when I got off work and tried(about 24 hrs later) the set and nothing happened when I went to start it up.took the fuse out put it back in started up.
  • jvolling1981 Nov 02, 2007
    p46813bl rca bigscreeen, wont come on, push power button and just clicks like it wants to but goes right back off, where did you find that fuse at so i can try to fix this bad boy
    thank you
    Jvolling01@aol.com
    Genius:
  • 1,074 Answers
The power regulater for your system have a short take it to a tech to have him fix it orelse you might cause further damage.
Posted on Feb 25, 2007
I have a zenith z42pq20 about a year and 3 month yesterday a hear a thunder, my tv was on, there.s a power failure and then the standbay light turn red but the tv doesn't turn on. The light doesn't...
Sounds like you took a hit. Unplug your set for 30 minutes and plug it bcck in. It could have just locked up the micro. If this does not fix, unplug the set and take the back off. Plug the set back in and check the powersupply for your 5 volts dc. If it is there, replace your main pcb.
Jul 20, 2011 | Televison & Video
1997 ZENITH TV WON'T TURN ON. UNPLUGGED, PUSHED POWER BUTTON FOR A1-2 MINS. AND PLUGGED BACK IN BUT NOTHING.
hiya mate if you have had this tv since 1997 exelent the life even for ordernary tvs is only 5 years time for a new one sorry mate
Dec 11, 2010 | Zenith Televison & Video
Green light flashes for about a minute, fan does not turn on and there is no picture or sound.
unplug all cords and cables from tv, then unplug tv, wait about 5 min, plug tv back in this resets, the "brain" if samething ....see if your bulb is glowing, or tv is hot to touch...always clean the breather slots or holes so fan can push or pull cool air..most of these tvs have a auto shut off for safety if fan has faulted out.....you might just have a DONE fan unit.
Jun 27, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv tries to turn on 3 times
Thats usually caused by bad capacitors or a bad flyback. www.tvrepairworld.com has the capacitor kits and the flyback kits available for your model.
May 10, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
WILL NOT TURN ON. GREEN LIGHT; TWO RED LIGHTS
check the projectors lamp.look like to need replace
May 05, 2010 | Hitachi 60V500 60" Rear Projection...
2002 akai 54in. rear projection tv wont turn on
Unplug,replug the tv back an hour later.The tv should reset itself.More problems repost,see if i can help u.
Feb 20, 2010 | Akai PT5492S 54" Rear Projection...
No power,no lights nothing!!
Hi,did you close the door cover?Make sure itsproperly shut other wise it won't tv light up. Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.
Dec 16, 2009 | Akai PT46DL10 46" HDTV-Ready Television
52 inch projection screen will not power up
Look for poor solder connections on the 4 bridge rectifier diodes. Looking from the back they to the right corner. Common problem.
Mar 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I am locked out of EXT 1 and do not have the remote control is there a default code to unlock the TV?
ok unplug tv for 5 min then plug back in and press and hold the power button for ten seconds this should reset the tv!
hope this helps
Dec 11, 2008 | Televison & Video
Televison & Video Logo
145 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
