Question about Compaq Presario Notebook
Windows xp dekstop icons not displaying
Hiii
I have a problem with a system. That is running with windows xp professional operating system. Now it has a problem like desktop icons not displaying. But background image its displaying. At that time we can go to taskmanager also. but icons and start menu not displaying. In safe mode its working. If we go for system restore also same problem.
  • Compaq Master
  • 32,281 Answers
1. Right-click the desktop, and then click Properties.
2. On the Desktop tab, click Customize Desktop.
3. Under Desktop icons, click to select the check boxes of the icons you want to view.
4. Click OK two times.
Posted on Dec 03, 2008
My dell volume icon is deleted
By default, the Volume icon is not displayed when you initially install Windows XP on your system.
To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
Thanks, Hope this Helps
Please Rate;)
Gary
Jul 30, 2013 | Microsoft Windows XP Professional
Tip
Make older programs run in Windows XP.
If you're having trouble running older programs originally developed for previous versions of Windows, you're not out of luck. Luckily for consumers, Microsoft built Compatibility Mode into XP. Compatibility Mode allows you to run a program using the shell of the original program it was developed for. Today Chris shows you how to access a program's Compatibility Mode in XP:
  1. Find the executable or program shortcut icon you'd like to run.
  2. Right-click the icon and select Properties.
  3. Click the Compatibility tab and place a checkmark next to the text labeled "Run this program in compatibility mode."
  4. Select the operating system that the program was originally intended to run on.
  5. You may need to fine-tune the three fields under "Display Settings" if an older program requires 640x480 resolution or 256 colors.
  6. Click Apply.
Try starting the program after making these changes. If it still gives you trouble, try a different operating system. If the program was written for Win95 and worked fine in Win98, there's nothing that says it still won't work fine with Win98.
on Jun 03, 2008 | Microsoft Windows XP Professional
I lost the product key Microsoft Windows XP Professional sp2
Search online for the PRODUKEY free software.
Download it.
Unzip it.
Run it, to display the 25-character product-key that you used when you installed Windows XP.
Apr 21, 2011 | Microsoft Windows XP Professional for PC
How to I check for sp2
Click on START then Control Panel, double click the System icon and it should display the version of Microsoft Windows XP.
Mar 02, 2011 | Microsoft Windows XP Professional
Hiii sir... I am using the Windows xp professional operating system.I am trying to install the audio drivers(intel) but it was showing an error as "This is not Intel(R) desktop board".So please assist me...
Normal 0
You can download the motherboard drivers from Intel WEB site. Select your model motherboard/device, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system.
Please click on this link and select your model motherboard : -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Oct 10, 2010 | Intel DG31PR Motherboard
Photo Streaming in LAN
I think best solution for you is VLC media player, you can download it from this link:
http://www.videolan.org/vlc/
May 03, 2010 | Microsoft Windows XP Professional
Explorer.exe Application error
Hi bj_bhuvnesh,
 Whenever internet explorer crashed, you would see the overwritten message.The best option would be to upgrade the browser if you are not using IE 8. You can also copy or format and again install the windows. Create a back up and than format the drive in which you have installed windows files.
Check the below mentioned :-
http://www.worldstart.com/tips/tips.php/2683
Thanks for using Fixya.
Apr 26, 2009 | Microsoft Windows XP Professional
Windows XP display..
Try clicking on the icons Holding on to the button & drag it to the left hand side.A more easy method is to right click anywhere on the desktop,click on Arrange Icons By Name,Size,Type & modified.Choose any one of the four options.Hope this helps
Jun 06, 2008 | Microsoft Windows XP Professional for PC
When I boot up my computer before windows xp loads it asks which operating system I want to run,and it gives me 2 choices WINDOWS XP HOME, or, WINDOWS XP HOME. You use the up and down arrows to select...
simply you can remove the second option in the boot.ini.
go to the or right click the my computer at the desktop and the properties. and then click"advance TAb" in the start up and recovery, click "setting" and then "edit"
you will see this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
Timeout=30 change to: 0
and then delete this:
after deleting you must save it.
and then restart the system
Please leave a comment b4 your rate, Thanks!
Jan 28, 2008 | Computers & Internet
Xp sp2
hi,
Try this,
Right click on my computer then go into the properties, on top theirs a tab called advanced, click on it. under Advanced tab their should be 3 options, 1 should called start Start up and recovery, click on its setting, then uncheck the box called Automatically restart. click OK, OK. restart the computer this should do the job.
hope this little info helps.
TY
Dec 20, 2007 | Microsoft Windows XP Professional With...
Compaq Presario Notebook Logo
150 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
