Question about Casio G-Shock G510D-1AV Wrist Watch
Problem with the time setting
My watch wont show the digital hours and minutes. When I try to set the digital time on the watch it wont let me set the hours and minutes. The digital time is not displayed at all under normal use only the date and day are cycled when you press the forward button. The stopwatch, Timer and alams can not be adjusted either due to the display not appearing. This all happened when I had the battery replaced. Please help if you can.
The only info which continually flashes is a dart and the letters chg
Posted on Sep 22, 2008
My Watch is showing military time but i want it to show in the 12 hr clock
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
http://www.fixya.com/support/t6812987-change_timex_wr30m_from_24_hour_12
How do change my timex wr30m from 24 hour to 12 hour display
Mar 21, 2018 | The Watches
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
I have a digital wrist watch and I can not set it up.
hi Claude.
Press and hold the "Adjust" button to until the "Time" digits begin to flash. Use the "Start/Stop" and "Split/Reset" buttons to set your digital watch to the correct hour and minute increments. Press "Mode" to display the "Date" setting screen.31 Mar 2015
Digital Watch Instructions ' Techwalla.com
https://www.techwalla.com/articles/digital-watch-instructions
How do u set a digital watch?In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.4 Button Digital Watch - Dakota Watchhttps://www.dakotawatch.com/PDF_FILES/Digital.pdfSearch for: How do u set a digital watch?
how to set digital wrist watch Google Search
Nov 27, 2017 | Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    How to set time on a 1440 timex watch
    Hi tsgoode99,
    To set the digital time and date on your Timex, please follow the steps below.
    Timex Digital Watch
    Hope it helps.
    Thank you for using FixYa.
    Dec 25, 2010 | Timex 1440 Nylon watch
    My timex 1440 sport watch has buttons that are slightly different than any manuel I can find on line. the buttons are as follows going clock wise from top left mode, stop/start,adjust,and indiglo. I just...
    Try this:
    To set time and date:
    1) With time and date showing, press SET.
    2) Seconds ?ash. Press START/STOP to round time to nearest minute,
    setting seconds to zero.
    3) Press MODE. Hour ?ashes. Press START/STOP to change hour,
    including AM (no symbol) and PM.
    4) Press MODE. Minutes ?ash. Press START/STOP to change minutes;
    hold button to scan values.
    5) Press MODE. Month ?ashes. Press START/STOP to change month.
    6) Press MODE. Date ?ashes. Press START/STOP to change date.
    7) Press MODE. Day ?ashes. Press START/STOP to change day.
    8) Press MODE. Time format ?ashes. Press START/STOP to select
    12- or 24-hour time format. 12-hour format has AM/PM.
    9) Press SET, at any step, to exit and save settings.
    Date (day of month) appears in upper part of display in Time mode.
    Press and hold START/STOP to see month and date in large digits.
    Jan 19, 2018 | Timex 1440 Nylon watch
    Timex 1440 time from 24 hour clock to 12 hour
    Hi bowingman,
    Hope it helps.
    Oct 09, 2009 | Timex 1440 Nylon watch
    Casio Wave Captor Watch wont set to correct time.
    You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
    Apr 21, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Need instructions for Timex 1440 Sport watch
    TIME AND DATE
    1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
    2. Press ADJUST to set SECONDS to zero.
    3. Press START/STOP to select MINUTES.
    4. Press ADJUST to change.
    5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
    6. Press MODE when done.
    7. To display DATE from Time display , press START/STOP.
    8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
    9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
    ALARM AND HOURLY CHIME
    1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
    2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
    4. Press ADJUST to change.. Press MODE when done.
    5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
    CHRONOGRAPH
    1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
    2. With time displayed, press MODE to select Chrono Mode.
    3. Press START/STOP to start.
    4. Press ADJUST to view lap time. Press again to sesume lap timing.
    5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
    6. Repeat for successive laps.
    Nov 22, 2008 | Timex 1440 Nylon watch
    Citizen Skyhawk Time Adjustment Problem
    It is possible to set the main analogue hour and minute hand 30 minutes out of phase with the digital readout, but doing so will also put the analogue UTC dial 30 minutes off. It can be done by using a variation of the proceedure for zeroing the watch hands as follows: 1. Rotate the crown in its normal opering position to set the watch in chronograph mode (mode dial pointing to "chr") 2. Pull out the crown to the second click. This should cause all the hands on the watch to return to zero. "HR" should appear on the left-hand digital display. This will allow you to move the hour hand by twisting the crown. Advance it to about half way between the 12 o'clock and 1 o'clock positions. 3. Press the top button. "MIN" should appear in the left-hand digital display. This allows you to adjust the minute hand. Twist the crown to advance it to the 6 o'clock, or 30 minute, position. Note that this will also move the minute hand on the small UTC dial to the 30 minute position. 4. Press the crown back into its normal position. 5. Reset the digital time and date according to a time zone that is in a one-hour offset from UTC. This is not a perfect solution. Your digital readings will show the correct time for all one-hour offset time zones while your analogue nads are 30 minutes out of phase. Your small UTC dial will also be 30 minutes out of phase with the digital UTC. Hope this helps.
    May 28, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
    Casio G-Shock G510D-1AV Wrist Watch Logo
    818 people viewed this question
    Top Casio Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    k24674
    Are you a Casio Watch Expert? Answer questions, earn points and help others
