Hi. My Brother DCP 115C is locked up. All I get is the red warning light - no error messages, and no response other than warning bleeps when I press any of the buttons. I have tried turning it on and off. There is no paper jam, and the ink cartridges are fine.
  • 1 more comment
  • johngwinters Dec 03, 2008
    Tried first advice - no luck. There is some sound of movement when I turn the printer on, and a few warning beeps, then nothing but the red warning sign on constant.
    Thanks Benimur. Did what you advised and the copying buttons now function ok., which is a start. I now have the Warning Light and Photo Capture Light flashing constantly. All other buttons (including on/off) are dead, and no text at all, so no error message/code.
  • johngwinters Dec 04, 2008
    Hi. What`s a hard reset? If it means restarting the machine from the mains, I have tried that. No luck!
    Sergeant:
  • 217 Answers
It could ve various problems about this red light error on the printer and very common reaSON for this error is low ink in the cartridges,as sometime the low ink message does not show up on the machine it directly goes to this red light error and nothing happens. to locate whether the ink is low or not u can try this instructions  Checking the ink volume You can check the ink that is left in the cartridge. 1 Press (Ink Management). 2 Press or to select Ink Volume. Press Set. 3 Press or to select the colour you want to check. The LCD shows the ink volume. 4 Press Stop/Exit. You can check the ink volume from your computer. (For Windows® users, see Status Monitor on page 1-3 in Software User’s Guide on the CD-ROM or for Macintosh® users, see Status Monitor on page 8-2 in Software User’s Guide on the CD-ROM.) Ink also there r many more troubleshooting issues given in the link below which i m giving u .just click the link directly and the link will downloaded in that lick after it downloads click the option trouble shoot that is page number 70 in that link. http://www.brother.com.ph/CMS/Product/File/DCP-115C_UserGuide.pdf
this is the link just click it directly and wait for couple of minutes to load.
Posted on Dec 04, 2008
    President:
  • 2,110 Answers
Warning LED indications
The Warning LED (Light Emitting Diode) lights when there is a
problem with your machine. You should check the LCD displays for
more details about the problem.
Red
Cover open The cover is open. Close the cover.
Ink empty Replace the Ink cartridge with a new one.
Paper error Put paper in the tray or clear the paper jam.
Posted on Dec 03, 2008
  • 4,806 Answers
Unplug the printer from the pc and remove power from the printer, then uninstall the printers software and then restart the pc so changes are made in the registry, then all you have to do is reinstall the printer as if from new!!!
hope this works for you and kind regards
    Genius:
  • 1,011 Answers
Dear sir,
Select Quit Printer Setup Utility from the. Printer Setup Utility menu and check the settings. Try to reinstall the printer driver.
click this link for troubleshooting and maintenance tips
thanks
good luck
    Genius:
  • 1,142 Answers
Do a hard reset that will take care of the issue
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your concern would require that the error code(s) be displayed by:
  • power off the machine by unplugging from the mains;
  • press and hold the "MENU" button down while powering on the machine;
  • maintain press & hold on the "MENU" button until error code is displayed.
If the above initial solution has merit, pls click on my "Ask Me" should you need additional information or postback here how things turned up and to explore your additional options.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Now I wonder if you would be able to see this subsequent post in reply to your comment "Thanks Benimur. Did what you advised and the copying buttons now function ok..."
    The "Warning Light" is a general failure indicator and that you are in "Maintenance Mode" while the "Photo Capture Light" refers to the built-in memory card reader. Initially, pls check that nothing is lodged inside the memory slots or better yet clean them with flattened cotton buds and then a spray of compressed air.
    Should you want to open up the machine and explore for loose wiring or connections, this page would be informative. Though for another model, the general procedures would be identical.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
    Guru:
  • 859 Answers
Try turning the platen on your own if you can then.
Unplug the printer. Leave it unplugged for several minutes and plug it back in.
You should be getting an error message.
  • Glenn Rogers
    Glenn Rogers Dec 03, 2008
    There is a jam. A jam that could be a broken tooth on a gear drving the platen for the paper.
    Please understand that normally we all have printers in front of us in the real world. Making these judgements over the internet is difficult.
    To resolve this, since there is no error message to work from, you may have to remove the outer covers of the printer and examine the entire printer carefully.
    Are you connecting your printer through an external USB hub or a USB port on the front of your computer?
    Regards,
    Worldvet
  • Glenn Rogers
    Glenn Rogers Dec 04, 2008
    A hard reset is when all power from all sources is removed for several minutes.
    Remove the USB cable. Remove the power cable from power. Leave it like that for a good twenty minutes. This allows the power circuit to fully deeneergize.
    Do not reconnect the USB cable. Connect the Power cable. Press the On button and leave it depressed for as long as it takes to get a diagnostic menu with reset option. If this doesn't happen. Remove power again for a good deal of time. This time when you apply power and turn it on press and hold the Cancel or Reset button down while pressing the power on. This time keep the Cancel or Reset down until the diagnostic or reset menu appears.
    If these two hard resets do not give you results, your problem exists inside the power train of the printer and it is failing during the power on self test. You will have to remove all the covers and examine the gearing for chipped teeth or bad belts if any. There is some impediment for the gears to all rotate until they find a home position. This may be beyond your scope of experience. In this case you will have to have it serviced.
    I've already looked in the databases for a reset sequence for your problem and none exists. This is not a good sign. Sorry.
    Hopefully, the hard resets will get you going or your examination of the power train gear paths will result in an obvious issue.
    Good Luck,
    Worldvet
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
Need windows 7 drivers voor dcp 115c
Hi, here is the link where you can get your required driver free for life.
http://www.lostmydrivers.com/printers-drivers/brother/brother-dcp-115c-printer-driver-a-win7-win7.html
Good Luck
Jan 14, 2011 | Brother DCP 115C All-In-One InkJet Printer
Printer won't print
..if not mistaken, the error message is Unable to clean, which indicate you will need to replace the waste ink pad and reset the waste ink counter.. you will need to send to the local service centre to get it done..
May 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Paper jam
see here how to open your dcp (same procedure as the mfc215):
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
The flashing of lights means that you are in the maintenance mode.
Apr 18, 2008 | Brother DCP 115C All-In-One InkJet Printer
My printer have problem
you need a new waist ink absorber box.
Search this forum for error 46 or unable to clean. the procedure is explained many times (identical for all brother inkjets)
Apr 17, 2008 | Brother DCP 115C All-In-One InkJet Printer
The error messageunable to init
you have to replace the print head.
But to be honest: its cheaper to buy a new dcp 135c or 130c with warranty and new carts incl.....
Mar 12, 2008 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C displays unable to init message tried the trouble shooter in manual still says it what should i do
press menu then start b/k-copy (mono) then fortimes arrow up button quickly after another. machine will switch to mainteance mode. press start bk copy.
What two digit error code does the machine display?
Post here again.
Mar 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
I cant to move my DCP-115 to the maintanance mode
First button is MENU then start b/k copy then 4x arrow-up....
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
42 people viewed this question
k24674
jasbo
jasbo
