SOURCE: Toshiba wont power on
Good afternoon!
From what you have told us, I would suspect that something got jiggled or joggled during the opening and putting back together process. I've done that to myself, in the past. ;o)
What I do in a case like this is as follows:
1-Power down and remove the battery (Leave the battery out until you get it running again)
2-Open it back up and disconnect and reconnect each and every cable and connector that I can find.
3-Remove and reseat the memory module(s)
4-Try to power back up.
If this doesn't do it, get back to me for some more diagnostics/ideas.
If you need
any additional information, please feel free to ask. If this information has
assisted you in the resolution of you problem, please return here to give my
assistance an appropriate final rating. If this information has answered your
question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
SOURCE: Toshiba Satellite A205-S4607 lights blink but it won't even post
Here you go bro.. Step by step instructions for dis-assembly HERE
pls rate high if this helps. ^_^
SOURCE: I was using mu Acer Aspire 7720G last night while
either plug in the back of the laptop is shot or you need a new hardrive
SOURCE: HP compaq 6730s laptop won't turn on
test all leads that attach to your hard drive including electrical extensions SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working might be getting hot check the CPU make sure it has thermal paste and dust free secure seating also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you
