Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60" Projection Tv - Approx 6 yrs old
Screen in showing white or glow in backround. Too much glare
  • Fred Giancola
    Fred Giancola Dec 06, 2008
    I have the same problem with the white glare and can't make adjustments with the picture convergence or any other picture menu options
  • Philips Master
  • 3,459 Answers
Your CRT fluid needs to be replaced. After many years the crt cooling fluid gets a ton of alage built up in the tubes.  This will cause the screen to get a halo effect or get darker.
You only need to replace the fluid in the blue and green tubes.
Posted on Dec 15, 2008
My 60" Philips rear projection tv began showing double & triple blurryness on the screen, what is the problem? Is it worth fixing? The tv is 9 yrs old.
hello it sound like the convergance ic may be the problem 2 large chips at the back of the tv usually behind the tuner board they sit on a metal frame called a heatsink also you will have to check the resistor in front of the ic and the 2 capacitors at either end
regards
shaun
May 28, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Large yellow blot on the left side of the screen.
that sounds like a very expensive repair I'm afraid
, it is the light engine that is bad
Larry D.
Aug 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red & green shadows
Replace the two STK392-120 Convergence Ics you can get replacements at the following link with step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Philips 60P8341 60" Rear Projection...
Fuzzy, washed out screen - fix was change crt coolant
A common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 04, 2008 | Philips 60P8341 60" Rear Projection...
Philps TV problem
When I turn the TV on, I get a horizontal line across the screen approx 1/3 from the top. My TV make is Diamond and is approx 6 yrs old
Mar 14, 2008 | Philips Magnavox 27MS343S 27" TV
60" RCA PROJECTION TV
my tv is 12 yrs old it started with the color starting to fade and then it started cracklin real bad and now theres no pic but there is sound
Dec 29, 2007 | RCA P60921 60" Rear Projection Television
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
