Question about Lexmark X4270 All-In-One InkJet Printer
Reinstall My printer was disconnected and now I'm having difficulty reconnecting. Could you direct me to a handbook on line where I may research the solution. Thank you Juanita
    Novelist:
    Champion:
  • 202 Answers
Juanita If you are using a computer re-insert your Lexmark install disk and un-install the printer. Turn the printer off and disconnect it from the computer and the wall. Go to this site and download the latest drivers for the printer http://search.lexmark.com/printer/US/en/21C2000 re-install the newest drivers and install the printer. If you are using the printer as a standalone unplug it from the wall for a few minutes then plug it back in. The above site should help. Good Luck, Tim
Posted on Feb 04, 2007
When I print, on the paper there is several blue verticle lines at the top of the paper and halfway down and some of the lines are broken. Thankyou Tom
Reset the Printer If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product. Make sure the product is on, and then disconnect the power cord from the product.
  1. Disconnect the USB cable from the product, and then disconnect it from the computer.
  2. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  3. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  4. Reconnect the power cord to the product.
  5. Press the Power button (c02062868.gif ) to turn on the product. If you have duplexer try to open it and clean the rollers of the printer and the duplexer. This usually happens if the rollers are dirty.
Mar 26, 2011 | Office Equipment & Supplies
Brushwacker dies after starting. how do you flush the fuel line?
I'm not sure of the equipment you are refering to. If it is a 4 cylce motor you disconnect the line from the tank, remove the fuel filter, then remove the line from the carburetor. If you have compressed air, blow through the line. Be carefull and point he line in a safe direction, junk will fly out of the line. Clean the fuel tank befor yoou reconnect, then reinstall lines and a new fuel filter.
Nov 07, 2010 | Sears Garden
Printer says that ink system failed.
Try this Step one: Remove the cartridges
  1. Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
  2. Open the product cover and remove the cartridges.
  3. Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
  4. Disconnect the power cord from the back of the product.
  5. Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
  1. Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
  2. Open the product cover and reinstall the cartridges.
  3. Close the cover and print a calibration page, if prompted.
  4. Print a self test report to make sure that the product can print.
  5. Reconnect the USB cable between the product and the computer.
  6. Try to print a document from an application on the computer.
Apr 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Photosmart 8750 carriage jammed error and skewed printing
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Jan 09, 2009 | HP Photosmart 8750 InkJet Printer
When i press print document it gets to about 20 25% then hangs it will not let me cancel it or anything iv reinstalled and still no joy
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.Make sure the unit is connected directly to the
walljack.still does not work..get it replaced.
Nov 26, 2008 | Lexmark Office Equipment & Supplies
Reinstall software each time the printer is reconnected
hmmm...maybe the way to do this is to use the remove hardware icon in control panel, instead of simply disconnecting the printer from the laptop.
also, go to www.hp.com and get the newest drivers, which are almost certainly more recent vintage than those on the cd.
Aug 20, 2008 | HP Photosmart C4280 Aio Printer
To Whom It may Concern, I have a Canon MF3200 Copier/Scanner/Fax Machine and I am having difficulty receiving faxes. I am able to send faxes, but receiving them is impossible. The phone rings...
I began the whole installation process (which required a CD) from scratch and followed the directions of the Canon handbook that accompanied the printer when it was purchased.
Jul 01, 2008 | Canon Office Equipment & Supplies
My printer was disconnected and when reconnected the output is cramped line on line. I have deleted the printer several times and reinstalled it but to no avail. How can I sort this problem out. Your help...
it seem that the printer has got lazy since it was disconnected ,try running a few pages through it to try and loosen it up ,also give the roller a clean it may not be griping the paper correctly
hope it helps you
Terry
Mar 12, 2008 | Computers & Internet
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
