I was on my Dell Inspiron 1525 and It was low on charge and when I took it off the power went out. When I turned it on again I chose Start Windows Normally out of a list of options. So it started up the Microsoft loading bar and then the mouse appears and then nothing happens. The mouse just stays there for a while and then it goes back to the Dell Startup loading bar and repeats the process. I have Windows Vista
  • 2,110 Answers
Try to boot into safe mode(by pressing F8 while booting)...If unable to boot in safe mode then u have to re install os again...
Posted on Dec 03, 2008
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 does not power up. i powered
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Apr 28, 2010 | Dell Inspiron 1525 Laptop
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
Sep 01, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 won't charge
The battery has most likely been "Over charged". Most rechargeable batteries can only be charged around 500-1000 times depending on the brand of your computer. I would recommend buying a new one.
May 30, 2009 | Dell Inspiron 1525 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
