Question about Biostar M6VLQ Motherboard
How much ram?
I have fitted 2 512m ram cards, only 504m ram shows up, I know the ram is OK . is there a way round this please?
  • griff22_petm Dec 03, 2008
    Thanks, but I've checked both RAM cards also a third, they are all identical, no combination makes any difference. In the manual it says "Supports a maximum memory size of 512 MB with SDRAM"
    So maybe it means what it says, or does anyone know better?
  • 32,281 Answers
It appears that one of your RAM modules may be incompatible with one another, or one module is faulty. Are the RAM modules from the same manufacturer and same specs/speed?
The motherboard may require interleaf memory and requires RAM to be installed in pairs in specific memory slots, check your manual.
To test for compatibility or fault, take both RAM modules out and insert one RAM module at a time in the memory slot 1. Boot up computer, if OK shut down and put the other RAM module in slot 1 and boot up again. This will determine the faulty RAM or incompatible module..
Your motherboard has onboard video chip and it uses some of your RAM for video memory, that is why it memory appears less that the normal RAM capacity.
Posted on Dec 03, 2008
  • Chris Hingee
    Chris Hingee Dec 04, 2008
    Your are correct, the manual says it supports a maxium of 512Mb RAM. There is a possibility that a BIOS upgrade from your motherboard manufacturer will make your BIOS support more than 512Mb RAM.
    If there is an upgrade available, be very sure of what you are doing, because if you screw it up your PC will end up as a piece of junk.
    If you elect to use a graphics card you will only gain 8Mb extra, as Mike stated, but if you get a PCI graphics card or preferrably a AGP graphics card (if your motherboard supports a AGP slot), the graphics will be heaps better, runs faster at a higher resolution and more colours because the graphics card has its own RAM. You will most likely need to get into the BIOS to disable the onboard graphics card.
  • 2,351 Answers
Hi griff22_petm,
It is not you. The Biostar uses an intergrated graphic card. In your manual on page 2-13 & 2-14. Advanced Chipset Features.
You can set the total amount of system memory for the graphics card to use. Currently you have the bios set to use 8Mb of system memory to run your graphics card. (A wee bit low). If you need the manual you can download it from Biostar at this link:
There is one other way to use all your system memory & that would be to buy a PCI video card, this would free up all your memory. Suggested PCI graphics card:
Good luck griff22_petm!
I need step by step instruction for installing memory
First check that you have bought the correct RAM.
Go to and select 'Get the correct memory'. and check the results with what you have.
If OK probably best to remove an existing RAM chip noting carefully how it comes out and which way round.
Broadly, there is a catch at the bottom on each side, that has to be released (with a small electrical screwdriver) then you pull up at an angle of 45 deg..The slot in the centre of the RAM will only match one way round. Then replace it and try the same with your new RAM in the next empty slot.
Apr 02, 2014 | MPC Computers ClientPro 414 All-In-One PC...
I have A dell gx270 desktop computer . i was searching on internet . Suddenly system hangs . When i restart computer it hangs on dell logo . i tried many time but it hangs on dell logo . i changed ram ,...
Firstly, make sure you installed the video card (if it has one) back into the same slot it was removed from.
If you are using on-board video, check the CPU is firmly seated into it's socket, you may have to remove the CPU fan to check this.
Next, check your RAM sticks again. Most (about 98%) of boot up issues arise from incorrectly seated ram sticks or ram sticks that have developed connection issues.
When you boot the machine, does it make any beeping noises..?
Usually, a single beep means all is ok. If you hear multiple beeps, then the bios is telling you about a possible fault and you should count the beeps for number and duration (long beeps or short beeps and how many of each and in what order)
Remove the ram and using some very fine emery cloth, gently remove any oxidisation from the contact pads to return them back to bright metal, then re install them making sure they are seated all the way down and the locking clips are fully seated too.
If you still have boot issues, I would suspect the ram sticks first and have them checked by installing them in another compatible machine, either a friends or at a repair shop.
I would suspect the board last so if the ram sticks check out as good, have a closer look at any other cards that may be installed, especially video cards and internal modems but also check out any network cards that may be installed..
If you are still not getting any display on the monitor, take the machine to a service centre or computer shop as they have the specialist equipment to check out the board electronically ( boot cards, scopes etc).
Let me know how you go and what you find..
Dec 05, 2010 | Dell OptiPlex GX270 PC Desktop
I am using Core 2 quad and my ram is 4GB but the ram is not showing 4gb when i turn on the pc its is just showing physical memory of 1.99 GB
32 bit operating system is limited to 4 gb but on a system fitted with 4GB or RAM and a modest graphics card with 512MB of on-board memory the end user normally sees about 3GB of installed system RAM. So what this means is that the realistic upper RAM limit for a 32-bit OS is more like 3GB. If you’re adding big graphics cards with larger amounts of RAM (or using Crossfire or SLI) then you’ll need to be seriously thinking about a 64-bit OS much sooner.
But it also might be that you have a bad chip try and start the system with one chip at a time if it starts with both then you know there good. Please post the results. ;)
Jun 17, 2010 | Computers & Internet
Computer turns on but will not beep or nothing shows on display.
1.On plug the Ram
2.Turn on the System without Ram
if you here Beep Sounds then problem with Ram.
3.Turn Off The system
Fit the same Ram Properly.
3.Turn On .
4.If not Ok,the Buy a New Ram and fit it properly.
Feb 12, 2010 | Gateway (4000274) Motherboard
When viewing some Utube videos my computer shows a few seconds of the video then stops to load a bit more, shows that and stops.... and so on.
you have a slow connection to the internet or your graphics card is to slow to view the video. If your using a phone line to connect to the internet thats your problem.
Oct 06, 2009 | Computers & Internet
My windows not shwoing whole RAM size
What you are seeing is correct. You have 4GB of physical RAM installed in the computer and it is being recognized properly by the BIOS. A 32-bit operating system can only address approximately 3.5GB of RAM. Vista may be rounding the number down to 3GB or if you are using on-board video, some of the RAM is being allocated for use by the video circuitry and is not reported as system memory. To see all of the installed RAM in your operaing system, you need to upgrade to a 64-bit version of Vista.
May 29, 2009 | Kingston 2GB Secure Digital Memory Card
RAM only shows that I have 384MB of ram
Does bios see the amount of ram that you are putting in? Press F2 when powering up and check to see if the bios is indicating ram amount as what you installed! Let me know what happens.
Apr 05, 2009 | Sony VAIO PCG-K23 Notebook
1 GB RAM showing 512 MB
That can be taken by The onboard graphics card. please have a look on oi on your bios menu.
Apr 04, 2009 | Intel Computers & Internet
My computer has a problem with card sound inside mother board.
Disable the onboard sound car in cmos , then plug in a pci slot fitting sound card, reboot, windows will report new hardware found, load the drivers, restart for changes to take effect, job done.
Nov 16, 2008 | Computers & Internet
Vivicam 5386 copying images to memory card
To copy pictures from memory to your memory card turn your camera on and press the button above the menu button. This will start showing the pictures already on your memory card. Next, press menu and the down arrow. This down arrow is located on the round button with the "OK" in the center. Your choices should be DELETE, SLIDE SHOW, PROTECT, QUALITY CHANGE, RESIZE, and the one that you want,COPY TO CARD. Press OK and the camera will copy pictures from internal memory to the memory card. This information is on page EN-62 and EN-63. I know that this works because I was testing the information as I was typing it!
Oct 02, 2007 | Vivitar ViviCam 5386 Digital Camera
Biostar M6VLQ Motherboard Logo
136 people viewed this question
Top Biostar Computers & Internet Experts
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
