Question about Dell Dimension 2400 PC Desktop
I can't get my monitor resolution to go above 16 bit medium
Need help please
    President:
  • 1,073 Answers
You need new drivers for your graphic card.
Here is dells downloadpage for Dell Dimenston 2400
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Good luck
Posted on Dec 03, 2008
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
Not able to use full screen
This sounds like bad resolution is set on your computer. The LG 22" FLATRON monitor has a native resolution of 1680 x 1050. However, your video card may not support this so you can also try any other 16:10 resolution like 1440 x 900.
To change your resolution in Windows XP:
1. Access the Control Panel.
2. Choose "Display".
3. Click the "Settings" tab.
4. Under "Screen resolution" move the slider to a 16:10 resolution like 1680 x 1050 or 1440 x 900.
If you computer does not support higher resolutions, you may consider replacing your video card to take full advantage of your nice 22" Flatron monitor.
If I can further assist you, please let me know.
Regards,
KYTechnology
Mar 01, 2011 | LG 22" FLATRON LCD Monitor
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
Ihave viewsonic lcd monitor va1616w. Display card is NvidiaGEForce2 integrated GPU. The resoultion is not coming correctly
Maximum resolution on this monitor is 1366x768. Check your color depth( 16 bit, 24 bit, etc) and do not set the resolution greater or you will get unpredictable results.
Brock
Sep 16, 2010 | ViewSonic VA1616w 15 inch LCD Monitor
NOT SHOWS RESOLUTION 1360 by 768 IN 16" WIDE LG LCD MONITOR MY MOTHER BOARD IS GIGABYT INTEL CHIPSET 865, PLS GUIDE US
Hi!
Installing the video card driver can make use of its features of higher resolution support for your LCD monitor.
And also install the driver of your LCD monitor. This enable to use higher resolution that could provide with your computer video card as I have mentioned above.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 05, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Hi,Have 710n when powered up shows "not optium mode" box and cant get into menu.How do you access menu? Many Thanks Bruce
In Your Desktop, Right Click -> Properties. In this Display Properties window, Click on Settings Tab.
Adjust the screen resolution to '1280 by 1024 pixels'.
Set Color Quality to 'Medium (16 bit)'
Then click on 'Advanced' Button. In Monitor Tab, Set the Screen Refresh rate to 60 Hertz. Click Apply/Ok in both the settings windows. This will Solve your Problem. Else, Try setting Color Quality to 'Highest (32 bit)'.
Oct 16, 2009 | Samsung 710N V2 17" LCD Monitor
Acer x223w issues- freezes
I think it could be an issue with resolution. Since the monitor is so big, some video cards, I noticed, can't support the high resolutions that the monitor can, if that doesn't work try 16-bit instead of 32-bit.
Feb 25, 2009 | Acer 22" X223w LCD Monitor
Default monitor
Sounds like you need to install your video card drivers, to get the resolution you need.
Jan 06, 2008 | Computers & Internet
Unable to install the canon Software
Under your control panel in "Display" go to the settings tab and slide the resolution bar to:
Screen resolution: 1024 x 768 pixels or more,
Color quality: Medium (16 bit) or more
That should do it.
Dec 06, 2007 | Canon PowerShot S5 IS Digital Camera
Dell Dimension 2400 PC Desktop Logo
133 people viewed this question
Alun Cox
