FixYa.com
Tags:
Kanguru KanguruClone 4 Hard Drive Duplicator  Hard Drive Array
Drives duplicated on Kanguru Kclone 4hd will not... (by 2 users)
posted by eerwin on Feb 16, 2007
When doing a resize copy using SATA drives or copying using an IDE master drive to SATA drives of the same size the resulting duplicates will not boot in a computer. We just get a cursor in the upper left of the screen.
If we copy SATA to SATA or IDE to IDE of the same size, we have no problem with the resultant duplicates booting.
I contacted Kanguru and was first told to upgrade the firmware. This had no effect, so I called them again and they had me send the unit in for possible repair. They called me back and said they could not duplicate the problem. They had gone from a 40GB drive to a 160GB with no problems booting. They told me the problem could be the SATA cables. However, this makes no sense because we can copy SATA drives successfully as long as the master drive is SATA and the copies are the same size as the master.
I have the unit back now and it is still doing the same thing. I have connected the duplicate I made to a computer(via USB) and all the data is there, but it will not boot up when connected as the boot drive on a computers.
This is perplexing and we paid a lot of money for this machine. If someone has a solution or suggestion it would be most appreciated.
Comment by eerwin, posted on Feb 16, 2007
I sent the unit in a second time with one of my masters and they said the master itself wouldn't boot in a computer even though I had tested it right before I put it in the box to send it in. I sent them another copy of it and they said it wouldn't boot either.
I wouldn't recommend one of these to anyone, just because of the support. It is simple to use, but unless I get a resolution to the problem we can only make same size copies which is not what was advertised.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Feb 19, 2008
I have the same problems
Can you Help with these Network Storage problems?
Network Storage
my suzuki step 125cc scooter is...
suzuki motorcycle 125 cc... Answer This...
Network Storage
micro sd 4gb micro card.
i just bought a micro sd card... Answer This...
Network Storage
LaCie Ethernet Disk mini...
I have a lacie ethernet disk... Answer This...
Network Storage
itunes card
can i purchase an itunes card... Answer This...
Repair Service
Find Network Storage Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
