Question about Whirlpool Duet GHW9150P Front Load Washer
Change rear tub bearing
I removed the rear panal, belt & pulley. i also removed the top, front panel & started removing the panel with the door. it is my assumption that you must remove the drum with the shaft & then knock the bearing out of the rear? please inform & possibly include some sort of break down. parts list??
  • Nicholas Redman Jul 02, 2013
    OK SO WHAT IS THE BEARING TYPE?
    President:
  • Whirlpool Master
  • 2,651 Answers
The nner tub and outer tub (rear section) need to be replaced,the bearing is mounted in rear section of tub, the entire unit is removed fromthe machine from the rear of machine in order to relpace. new pulley, nut, as well. not and easy job, and can be very costly paying for those parts.
Posted on Dec 04, 2008
Need to change front and rear bearings
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
(tip courtesy JSRock)
Thanks for using FixYa!
Dec 12, 2010 | Washing Machines
Kenmore HE2 Plus Front Load Washer The bearings at the large pulley are shot. Can I just replace the bearing or do I have to replace the back half of the outer tub? Can the bearing be replaced from the...
DISASSEMBLY:
REASSEMBLY:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 12, 2010 | Kenmore HE2 Plus Front Load Washer
Rear bearings are shot!
Rear Tub Bearing Replacement Whirlpool Frigidaire Kenmore Front Loar Washers
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
DISASSEMBLY:
REASSEMBLY:
Sep 05, 2009 | Kenmore Washing Machines
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Change drum bearings
DISASSEMBLY:
REASSEMBLY:
Jun 12, 2009 | Washing Machines
How to change a washing machine bearing?
DISASSEMBLY:
REASSEMBLY:
Jun 08, 2009 | Washing Machines
Need to change bearing
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DISASSEMBLY:
4. Remove the lower panel under the door (if you haven’t done so in the previous step) and remove the washer top and back panels.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o’clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
REASSEMBLY:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o’clock position.
- With both hands gradually work your way around to the 4 and 8 o’clock positions and stretch the spring apart.
May 09, 2009 | Washing Machines
Worn out drum bearing and seal
DISASSEMBLY:
REASSEMBLY:
Apr 09, 2009 | Washing Machines
Bosch WFF2001 washing machine motor bearings failing
This advice is for replacing the rear wash tub shell of most FRONT LOADERS. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
DISASSEMBLY:
REASSEMBLY:
Jan 05, 2009 | Washing Machines
How do you replace the rear drum bearing on the dryer? It heats and tumbles but makes a terrible squeaking noise in the process! We have the part # 131825900. Our dryer is a ten year old Tappan...
Hello Jkahle9,
You are in for a big job there. I will try to give you the best step by step possible. First get you a rear bearing part number 131825900. This part retails for $5.96 but you may pay as much as $11.99 This is only for the bearing not the ball that goes on the back of the tub. You will also need some white lithium grease. You will put a small about inside the rear bearing.You may also want to have a second person to help screw the bearing in place.
Step one will be to unplug the machine and pull it out so you will have access to the back. Most of the repair will be done from the front of the machine.
step 2, You will need to pop up the top of the machine. You do this by inserting a flat blade screwdriver into the two clips holding the top down. They are located about two inches from the left and right side front under the top.
Then you will need to remove the front panel and door. You will do this by removing the two screws from the top left and right of the inside of the front panel. the front will then tilt forward from the top and lift off. Use caution because your door swith will still have two wires attached. You can leave these inplace.
next will be to remove the belt from around the tub. To do this reach underneath the tub and remove the belt from the idler pulley and the motor shaft. Remember how you take this off because you will be putting it back shortly. When the belt is loose you will use it to lift the tub upward with a sharp ****. The rear of the tub has a ball and socket joint and the ball must be pulled up and out of the bearing. When the rear of the tub lifts up you will then remove the tub out the front exposing the rear bearing and the heating element. Note, If you damage the heating element while doing this you will need to head back out to the appliance store and buy a new one. You can not take extra slack out of the heater if you have stretched it.
The final step will be replacing the bearing. Use caution so you do not loose the small ball bearing in the rear center of the bearing. You will have two screw to remove and a small metal bracket on the back of the machine. When reinstalling the screws you may need that second person to hold this bracket. Once installed and the small ball bearing is inplace add the grease. Look at the ball on the back of the tub to make sure it is not bad. If it looks ok then just reassemle and start drying. Good luck. MCA0824@aol.com
Apr 29, 2008 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
377 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
