Question about Xerox Phaser 8550DX Laser Printer
How can install hdd in laser printer - Xerox Phaser 8550DX Laser Printer
  • 37 Answers
The HDD in this machine is installed in the back of the machine. Power machine off and and remove the two thumb screws on the back cover. The HDD actually is installed on the cover that you remove. You need to get Xerox's HDD kit though to do it. It comes with all the neccessary connections and cables. Its part number is 121K44411.
Hope this helps.
Posted on Dec 04, 2008
How to remove hard drive before discarding this laser copier. I do not mind destroying the unit.
Dera
Open the back cover, at main controller PCB assy. you will find the HDD. disconnect and unscrew it . However the HDD is encrypted its very probably impossible to extract the data in case its used with canon.
Thanks.
Mar 04, 2015 | Laser Office Equipment & Supplies
Bizhub c253
will require install kit do you have that and the hard drive kit to seperate kits
Feb 12, 2014 | Konica Minolta bizhub C351 All-In-One...
Bizhub c450 scans multiple pages to separate scans
hi im lorenzo and i have been fixing konica minolta machines for about 2 years well lets catch to the case.
If you still have problems or cant change to multiple scan.
1.you have to get in the simulation mode because machine doesnt know if the HDD installed is in.
*simulation utilty/counter =details stop 00 stop 01
2. ONCE YOUR IN LOOK FOR SYSTEM 2 AND CLICK ON HDD YOUL SEE THAT HDD IS NOT INTALLED SO CLICK INSTALLED AND THEN EXIT END AND REBOOT THE PRINTER AND TRY TO SCAN AND IT WILL WORK
THUMBS UP IF IT WORK FOR YOU
Jul 18, 2012 | Konica Minolta bizhub C250 All-In-One...
How can i dowload brother hl printer for window xp?
Brother HL-2040 Laser Printer driver--->click here to download -->for windows xp .
  1. Please make a temporary directory on your HDD to save the downloaded self-extracting file. e.g.. C:\bront
  2. Start downloading.
  3. Once downloading is complete, double click on the downloaded file to extract it.
  4. Double click "SETUP.EXE" file in the following directory:
    XXXXX \ Driver \ inst \ XXXXX \ SETUP.EXE
    **At "XXXXX", a language name will be located. It varies on the language.
  5. The installation will start. Please follow the installation screen directions.
Nov 28, 2010 | Brother HL-2040 Laser Printer
What is error code E602-0001?
Turn on the copier (using switch on right side of copier) and hold down the 1 and 9 keys. Blocks should fall on the screen. This may take a while.
If this works, you'll then need to reload the firmware onto the copier using SST.
If this doesn't work hdd is dead.
Either way you'll soon need to replace your hdd and use SST to install the firmware onto the hdd. I suggest calling your tech.
The IR3300's a great machine. With the optional network print kit installed it can be use to print and pull scan, not just photocopy. This machine was built to last. Take care of it and it should keep on going for quite a while yet.
Nov 30, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Image Runner 2200, receiving error message 602-0003
It's related to copier HDD try with some technician to replace HDD or reinstall HDD software.
A data read fault of the HDD is detected when the HDD is started up. or
The wiring is faulty (short circuit, open circuit). The HDD is faulty.
also check -
Are the connection and the cable between connector J1025 of the main controller PCB and the connector J2005 of the HDD normal?
Jun 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Konica minolta B250 scan to HDD problem
What number are you trying to give the box? It needs to be a three digit number I believe.
Do not try to go in sequence, just give it a number like, 111, or 222, this will be sure as not to conflict with any exsisting boxes.
Aug 09, 2008 | Konica Minolta bizhub C250 All-In-One...
Hard drive on Bizhub 350
you have to order it form KM service, because, there is also special cabel and metal plate to install hdd, and installation instruction is included.
good luck
Apr 14, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Need solution
try set hdd not installed, then reboot and then change it back maybe you have to reboot again and then try to format. if the format is not complete, you can chooce not installed again and take out the hdd and connect it to your laptop and try to format it. the hdd can be faulty and neeeds to be replaced.
Mar 24, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
E602-0001
This is HDD error . The Hdd on the copier is failing or the system software is corrupt. Try installing system software first and if problem remains than need to replace the hdd, same as the laptop one 2.5"
Jan 22, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Xerox Phaser  8550DX Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
