Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer has a problem which causes a 'hiss' through speakers.
I've swapped out the sound card for a new one - no effect.
I've tried different speakers - no effect.
I've replaced all the cabling and checked the power cables and their arrangement - no effect.
I plugged the speakers into a seperated output (my ipod) and the sound was great! No Hiss!
So what do you guys think it could be?
  • fogarin Dec 03, 2008
    Thanks, but its a hardware problem as described above - software doesn't cause electrical noise.
    Anyone else?
  • fogarin Dec 20, 2008
    Yeh it appears to have fixed the hiss completely!
    Always the last thing you try!
    fricken eh'
    Cheers anyways,
    fogarin
  • 61 Answers
First uninstall your audio manager . install it after system restarting
Posted on Dec 03, 2008
Im using a behringer ucg102 guitar/usb interface, im getting a very bad hum/hiss.. i've tried 3 different guitars and multiple jacks. im not running any guitar effects yet, i've removed the...
Try this using a differeent computer. Some computers generate a lot of digital noise. Also use a lot of gain from the guitar to improve the signal to noise ratio.
Jul 23, 2011 | Behringer energyXT2.5 Plus Portable...
I have a lap top easynote TJ75 .with no valid reason my right speaker is not working properly.Sometimes it makes sound with hissing or sometimes it plays normally with hissing.The last thing I did was to...
if these speakers are external as it looks like
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
if its still under warranty take it back
hope this helps
Jul 18, 2011 | Packard Bell Speaker Computer Speakers
My daughter unplugged a speaker. I plugged it back in and now I don't get sound. I've checked to see if they are working properly and they are. Any solutions?
hope this helps
Jul 13, 2011 | Logitech X-530 Computer Speakers
Aego M 2:1 system. No sound from right speaker when connected to right channel, but speaker works when connected to centre or left channels (although stereo effect not great when on centre). Computer: iMac...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Apr 29, 2011 | Acoustic Energy Aego M 2 Speakers
Hissing from computer speakers and they are new
Hello
A hissing sound indicates the speaker amplifier has no input from the computer sound card, check to make sure the speakers are hooked up to the correct port for audio out to the speaker input, the Audio output to the speaker is the GREEN mini RCA jack on the back of the computer.
Dec 30, 2010 | Bose Companion 2 Series II Multimedia...
Help! Only my right speaker works on my new speakers! Do I need a new sound card?
USB headphones and speakers tend to operate independently of the PC's sound card, but you can determine if your sound card is the problem by plugging the speakers into a different computer. If both speakers work on a different computer, then the problem does lie in the original computer. If so, try a different USB port, especially one that is directly on the computer, not in a usb hub.
If only one speaker works on a different computer, I would troubleshoot the cord that connects the left speaker to the right speaker. Perhaps it is damaged or not connected fully.
Hope that helps.
Oct 15, 2009 | HP USB Powered Speakers . Computer...
Distorted sound from new Dell desktop
1. In most cases the problem maybe due to the powersupply. If the filter capacitor or the diodes are not working properly in the power supply, it could give the distortion sound. Use a different powersupply to see if it solves the problem.
2. The mic wire can also catch some hissing noise sometimes. Disconnect the mic wire from the motherboard and see if it solves the problem.
Thanks
Jul 02, 2009 | Dell Inspiron 530 Desktop Computer
IBM COMPUTER -- SOUND BLASTER SOUND CARD PROBLEMS
I presume you are going in through the mic socket on the audigy?
If so the most likely cause is a mismatch between the mic and the mic amplifier on the card, they are designed for cheapo condenser mikes that have a fairly high output.
Also make sure you disable any inputs that ar'nt in use to minimize noise.
If you have the Mike plugged into the line in you have it in the wrong socket.
The best way to get a good result is use an external mic amp or mixer and go in through the line in. Again make sure you disable any inputs your not using (in the computer mixer) and turn down any sliders on the external mixer that ar'nt in use to minimize noise.
If you'r still having problems get back to me with a more detailed description of your setup, whats plugged into where etc...
Best of luck
Jun 07, 2008 | IBM Creative Sound Blaster Audigy Sound...
Webcam Speakers Echo and Double Feedback
"Noise", as used in this document, is a general term referring to any sound a speaker system makes that is not part of the original source material. There are many different types and sources of noise, each with its own solution. Below is an explanation of the common types of noise, what causes them, and how to minimize their occurrence.
Hum or Buzz
There are four common causes of humming and buzzing:
  1. Sound card If the humming or buzzing gets louder or softer with changes in the volume setting, this is an indication of noise coming from the sound card. In this case, check all of the connections to the sound card to make sure they are all completely plugged in and secure. Then, adjust the level setting of the sound mixer to obtain the best performance. Generally, you should leave your CD volume settings in the mixer at full and reduce the sound card's master output level down. For information on doing this, please refer to your sound card manufacturer's documentation.
  2. Unused input cables If you are not using all of the source inputs to your speaker system (such as using a 5.1 speaker system with a 4 channel sound card), the unused input cables will pick up noise. The solution is different for each speaker system, as described below:
    Z-540 / Z-560 (2 channel sound card): Depress the M3D button.
    Z-640 (4 channel sound card): Depress the Matrix button.
    Z-680 (2 or 4 channel sound card): Disconnect the unused input cables from the control pod
  3. High-power devices If you are using other high powered devices on the same electrical circuit, they may be causing hum or buzz. If so, discontinue their use while you are using your speaker system. Examples of such devices include microwave ovens, halogen lamps, power tools, etc. Also note that high-power devices with dimmer switches (such as halogen torchiere lamps) will cause an especially pronounced buzzing effect. To minimize hum or buzz, make sure that the dimmer switch on these products is either all the way on or off.
  4. Electric Polarity In many countries, the US being one, the electrical power grid is polarized. In these countries, the power plugs are designed so they can only be inserted into the wall socket in a single direction. For example, in the US one of the plug blades is larger than the other. To avoid humming and buzzing, both your computer and speaker system must be properly plugged into polarized outlets. If your wall outlets do not have polarized plugs, as in the case of many older homes, and you are using adapters to plug these power cords into the wall, it is possible that the polarity of either your computer or your speaker system is reversed. In many other countries, such as most of the European continent, wall sockets are not polarized at all - making it even more difficult to properly match the computer and speaker system. To solve the problem you will need to remove the power plug from the wall outlet, rotate the plug 180°, and re-insert it into the wall. Try this for your speaker system power cord, your computer power cord, or both. You should be able to find a combination that will eliminate the humming and buzzing.
Pops and Clicks
There are three main causes of pops and clicks:
  1. Sound Card Many pops and clicks are created by the sound card. There are two common causes: sound card quality and older or mismatched drivers. If the overall volume level of the pops and clicks goes up and down as you change the volume on the speaker system, the noise is being generated by your sound card. Lower quality sound cards don't include the necessary circuitry to cleanly remove noise from the sound output. Logitech's higher-powered systems, such as the Z-560 and Z-680, are also sensitive to the overall quality level of the sound card. If you are using an older or lower quality sound card, we suggest upgrading your sound card. The other primary cause is older or mismatched drivers. Make sure you are using the latest drivers for your sound card.
  2. Multi-tasking If you are running more than one program on your computer that accesses the sound system at the same time, small pops and clicks can be common. This is a function of your computer and/or sound card. A common example is using a program that generates occasional audio feedback (such as beeps or other sound effects) while listening to an MP3 track in the background. The solution is to turn off audio feedback in the first application so that the background MP3 track is uninterrupted.
  3. Interrupts in the Digital Bitstream On digital systems, such as the Z-680, it is normal to hear a very faint "tick" when you switch between inputs (by pressing the input button). You may also hear louder 'clicks' or 'pops' on a device such as a standalone DVD player or a sound card if it is plugged into one of the digital inputs. On some systems, this noise may occur when skipping tracks, switching audio streams (for example, from Dolby Digital to DTS), or navigating a DVD menu. The clicks and pops occur because the device is sending out an interrupted digital data stream. This behavior generally occurs with older software and older players, but is uncommon on most modern equipment. The Z-680 has been extensively tested with the latest sound cards, software DVD players, and standalone DVD and CD players. If you experience extensive popping and clicking, we suggest upgrading to the latest version of your software DVD player or, if using a stand alone device, trying a different speaker model. If you need more assistance with this issue, please contact Customer Support.
Stutter
A stuttering sound track is an indication of either insufficient or conflicting computer resources. Check to make sure that your computer has sufficient processor power and memory to handle the applications you are running, especially if you are using a software DVD player. Defragmenting your hard drive may also help. If you are sure you have sufficient resources, check to make sure that you don't have any conflicting IRQ or DMA channels.
We have also seen some software DVD player/sound card combinations that cannot properly output a Dolby Digital or DTS signal through the sound card's S/PDIF digital connector. (S/PDIF is a generic term for either coax or optical digital connections.) The result, when using a Z-680 hooked up to a S/PDIF connector, is a stuttering soundtrack. As mentioned, this stuttering is caused by the computer, not the Z-680 speakers. Switching the software DVD player's sound output to the 5.1 analog outputs will generally solve this problem.
Hiss
All high-powered amplification devices - everything from multimedia systems to home theater systems to movie theater sound systems -- generate some level of background noise, or hiss. In addition, low quality sound cards with poor signal-to-noise ratios can generate a significant amount of steady hiss that is reproduced on the speakers. Under normal conditions at a normal listening distance, the hiss coming from the sound system should not be noticeable. In a very quiet room, or if you place your ear very close to the speaker, you may hear a very low level hiss. This is normal, but should be completely masked by normal music and game sounds.
If you find that hiss is noticeable, it is likely that the speakers are too close to your listening position. If the speakers are too close, you will not obtain the best imaging of the sound and you risk damage to your hearing when the system is playing at full power levels. Try moving the speakers further away from your normal listening position. We recommend at least 18" for the moderately-powered systems (such as Z-340, Z-540, and Z-640) and at least 30" for higher-powered systems (such as the Z-560 and Z-680).
Also, note that the satellites in most Logitech speaker products are designed to be wall-mounted. Wall mounting the speakers provides two benefits: 1) it moves the of the satellites further away from your listening position, making any hiss less noticeable and 2) it moves all of the satellites further away from each other, providing better channel separation and surround sound spatialization.
Feb 16, 2008 | Logitech Webcam
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
62 people viewed this question
Alun Cox
