How can i reboot a zyxel router - Computers & Internet
  • Anonymous Dec 03, 2008
    gfd gfd gf dfgfgf gfg;fkglfkgl;dkfgflk
    Sergeant:
  • 302 Answers
There should be a reset button, use a pen or toothpick to press the button
Posted on Dec 06, 2008
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords
Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next?
Login to Your ZyXEL Router Using the Router Password
Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: ===============
Forgot Router Password?
If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings.
What should you do?
Login to Your Router Using the Default Router Password
Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides.
Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!)
Find Your Default Router Password
Simply select your router manufacturer from the list below to display the default router passwords and usernames.
Nov 02, 2014 | Zyxel Computers & Internet
I donot remambar password
Most default user credentials are - admin/admin.
If you are unable to log in, then most routers come with a reset key. For Zyxel NGB-417N router, press the reset key with a pin. hold on the pin till the device reboots.
Login with the default user id and password and setup the router.
Sep 30, 2013 | Zyxel NBG-417N Wireless Router
I have a zyxel pk5001z router and when i try to connect a wireless device to it i get a message that tells me the password is incorrect. any suggestions
GENERAL ROUTERS RESETING 1-With the unit on, place a paper clip into the hole on the back of the unit labeled Reset.
2-Hold paper clip down for 10 seconds and release.
3-The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults
Apr 07, 2013 | Zyxel Computers & Internet
I have a ZyXEL EQ-660R-F1 and a Linksys Wireless Router (B BEFW1154) that I'm trying to hook up. Can you tell me what I need to do?
Who is your ISP (internet service provider)? Anyway, it is possible to get your set up working. ZyXel is the DSL modem gateway and Linksys, your router/wifi. If you are able to get online by hooking up directly to the Zyxel, then it is possible to add the Linksys to the system.
Dont hook up the Zyxel to the Internet port of Linksys just yet. First you have to configure the Linksys by connecting your PC to it with a cable. Boot up the PC.
Open web browser and enter the address 192.168.1.1 and hit enter. This is the default address of the Linksys. username = admin and no password. It is probably the same as the Zyxel which causes the conflict.
The first set up page may look something like this below.
Change the LAN IP address from 192.168.1.1 to 192.168.2.1
Then click apply...From now on the Linksys IP address is 192.168.2.1.
Now you can connect the Linksys internet port to the Zyxel. Reboot the Linksys and Zyxel.
Your PC should be on the internet after that. To check/setup wifi, you need to log back into the Linksys using the new adress x.x.2.1
Feb 15, 2013 | Zyxel Prestige 660R Router (91004397002)
Zyxel NBG4115 disconnects quite often. Reboot of the router helps.
This kind of routers are, usualy, very sensitive to change in the flux of power. If you plug this router to a decent UPS should fix your problem.
Feb 28, 2011 | Zyxel (91-004-361002) Wireless Router
My new laptop keeps losing connection with my ZyXEL P-660HW-T1 V3 router. My old lap top worked fine, what could be the cuase?
The new laptops are not compatible with some of the older model routers.Try turning the power to the router for approximately 10 minutes,shut down your laptop before turning off the power to the router.once the router has been off for ten minutes,turn your laptop back on,as if you are "logging on",let your laptop be idle for about 20 minutes,giving your router time to "reboot" If this does not fix your problem,you'll have to replace your router with one that is more compatible....
Feb 12, 2011 | Zyxel P660HW-D1 Router
Connecting using wireless
because of zyxel support only zyxel product only
Apr 03, 2008 | Zyxel Prestige 660R Router (91004397002)
Installing wireless router
um is it compatible with vista and/or upgradable?
Jan 15, 2008 | Zyxel Prestige P-330W Wireless Router...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
