Wash setting numbers keep spinning and no wash starts?
  • natren Dec 03, 2008
    It's an Ariston Margherita 2000
  • Washing Mach... Master
  • 3,463 Answers
If the washer has a reset point, try resetting it.
Then try unplugging and plugging it back in again.
Clean plug with a dry lint free cloth.
I f still does not work, then you are probably going to have to call someone.
Posted on Dec 03, 2008
Whirl pool top load washing machine directly goes to aqua save mode and disable all other functions?
This is just a setting error. For troubleshooting of this error, just enter in diagnostic mode. Keep pressing Program button and then also press Water Level button. Now release both buttons. Now machine will auto run for wash-rinse-spin. After it finishes, Keep program on Normal, Keep water level low and now Start the machine. It will now work normally as before.
Nov 17, 2012 | Whirlpool Washing Machines
Not spinning "dry" after wash / drain cycle
What is the model number of the unit?
Nov 14, 2012 | Samsung Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Going through wash cycle but not spinning
my indesit starts to wash then comes up with 3 falshing lights and just keeps leting in water if i put the machine on with nothing in it it goes the wash until it gets to spin then starts to spin and agian starts letting in water
Mar 26, 2010 | Indesit W 123 Front Load Washer
Washer stops agitating durning the rinse cyle, but timer keeps going. Also won't wont spin the water out on the rinse cycle. Wash and spin work just fine. This problem is the same on all three cycles.
I suggest you replace the control box. I need Mgfr & model # to find the part number for you. The replacement steps are more mechanical than electrical. Oh! make sure you UNPLUG unit before starting repair.
Feb 11, 2010 | Washing Machines
The wash time continues to increase on every cycle. I have a Maytag Neptune TL Washer.
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
At the end of the spin cycle, my Kenmore Washing Machine makes a grinding noise like an out of balance brake drum. What could be the problem
If your washer model number starts with 110. it's a whirlpool washer. Whirlpool use a spin tube with two notches in it. There is a block assembly that holds the inner basket down on to the spin tube. This can be accessed by removing the top of the agitator and take out the 7/16 screw. Lift the agitator to expose the top of the spin tube. The tube is stripped on top where the basket sits. When the washer stops spinning, the inner basket keeps moving. That is the noise you hear. Replace the spin tube and possibly the block.
Oct 03, 2009 | Washing Machines
Selector switch
it is telling you, your machine has a problem you need to tell me what program are you putting it on. if you put it on a spin only and it keep going round What you need to do is turn the machine of and open the door leave the door open and put the machine back on set the program to the spin only and then shut the door press start do touch the machine till its finished that should help Its called a reset. if you have the same problem get back to me and i will help you ok.
Jan 05, 2008 | Washing Machines
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
