Question about Furuno Fr8062 12.1 Color Lcd 6kw 15 Meter Cable No Antenna
Furuno Radar 1623 and 1715
My questions is the Antenna cable for the Radar Furuno 1623 is the same like 1715 ???
Thanks a lot for your caring
    Problem Solver:
  • 8 Answers
Hello.
According to the operating manuals of the two radars (found on Furuno's Website (www.furunousa.com), they do use the same antenna cable.
Hope this was helpful.
Posted on May 04, 2009
  • erwin dj Apr 08, 2017
    Is the same cable.
Furuno 1623 Radar Power Cable
pn 000-147-564 from a Furuno dealer in your area. ($60 msrp)
May 16, 2014 | Furuno Fr8062 12.1 Color Lcd 6kw 15 Meter...
Furuno radar
Your antenna seems to be mis alighned. Its ZERO point must be readjusted.
Aug 30, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Can a furuno 1835 cable be cut, spliced & shortened
Sometimes shortening the cable by a lot will cause a timing issue (center spot or hole). The answer to your question though is yes.
Feb 05, 2014 | Furuno 1835 4kw 24 Dome 10.4 Color Lcd...
Ca I buy a 5 metre extension cable as the 10 metre cable that came with the 1623 is too short?
Quite sorry but Furuno does not carry "extension" cables for radar antenna signal cables. If the original cable is too short, you would need to obtain a 15M whole cable, furuno part number 001-122-870-10. Or the 20M whole cable part number 000-144-565. You might be able to find a technician willing to custom manufacture an extension for you but I emphasize the word might.
Regards,
John
Feb 18, 2012 | Furuno 1623 Radar 16nm Range
We have a radar Furuno 1622 - the scanner scans but sometimes we got echo and targets, sometimes none, sometime we get echos and targets on a small range display (1mile) but none on 2 or 4 miles range,...
I know this question is very basic, but did you check your gain and clutter settings? That echoes show in short range, disappear, reappear, and are not consistent on long range sounds normal to me. Auto settings sometimes also can get a bit mad, then manula settings makes sense.
Did you run the unit and scanner test?
Dec 04, 2010 | Furuno 1715 LCD Radar System GPS Receiver
Furuno GaAs FET Front End 4 Tone Daylight Display - when closing the DC breaker for the rada unit, the 10 amp fuse blows. Don't have a schematic. Don't know the model number. There are no data nor...
unplug the radar from it and turn on the display. If that does not blow the fuse, then your problem is either in the cable to the antenna or the antenna itself. Start there.
Nov 10, 2010 | Furuno 1715 LCD Radar System GPS Receiver
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
IS THERE A EXTERNAL ANTENNA AVALIBLE . IF SO WHAT MODLES CAN I USE THANKS MODLE 1623 FURUNO .
I would assume you're talking about the radar? it's a RSB0093-074 it's just for the 1623. There are no other options. If you're referring to gps antennas then any antenna that outputs nmea can be used.
Jan 25, 2010 | Furuno 1623 Radar 16nm Range
Connecting power inside Furuno DRS4D
polarity is maked on the shield, on a sticker #1 is positive, #2 negative BTW, this is 48V DC (not 12V) supplied from a MFD8, MFD12, or MFDBB only.
Jul 05, 2009 | Furuno Navnet 1964CBB/NT vx2 Radar C Map...
Furuno 1623 Radar reading "no heading pulse"
The messages “NO HEADING PULSE” and “NO BEARING PULSE” means that the display is not communicating with the scanner (antenna). Both of these signals are generated in the scanner if you get this error check that the antenna cable is firmly connected and that the contacts are clean and corrosion free.
If the connection at the display looks good and feels like it’s properly connected, check the cable for any damage If you find damage you could try to repair the wires BUT (because of corrosion and moisture problems) IT IS STRONGLY REMENDED that the cable be replaced, but it’s kind of expensive $275.00.
The Part number is 000-130-034. Depending on the marine shops in your area they may have it in stock (or they can order one) but you can get it directly from Furuno at;
http://www.furunousa.com/Furuno/Rooms/Search/ProductPropertySearchResults?_webrFormIdentity=com.webridge.layout.FormLayoutExImpl%5BOID%5B47F81E95CB197F4C8708859EA0E22F08%5D%5D&_webrFormUniqueID=0&_webrCharacterEncoding=iso-8859-1&_webrLocale=en-us&_webrClusterUpload_2=&ptype=com.webridge.entity.Entity%5BOID%5BE670694808555649838ED263AA4CAB0A%5D%5D&productname=000-130-034&searchOption=normal&searchOption_webrHidden=radio
I hope it’s just a loose connection. Good luck!
Apr 28, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Furuno Fr8062 12.1 Color Lcd 6kw 15 Meter Cable No Antenna Logo
580 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Colin Stickland
Colin Stickland
Are you a Furuno Boating Expert? Answer questions, earn points and help others
