Question about Argox OS-314 Label Printer
Need label file
I am balamurugan.I am working in HKETL in chennai.Here we are using one barcode printer for printing the label.Now we are decided to use argox printer,so we need label file for supporting in argox. HKETL is mobile service centre.We need soluton for these problem.
Thanks
  • ufuk May 11, 2010
    please could you give detail
    Problem Solver:
  • 16 Answers
Hello Mr.balamurugan
I think you are asking about printer consumables. Like Barcode Labels or Pre-Printed ones.
First thing, you need to buy the labels from the direct labels manufacutures and avoid buying from the resellers.
We have some common sizes like 50 x 25 or for little big labels like 100 x 50 .
Rates vary depending on the volume,
if you have not purchased the printers, i recommend you to take a look at these printers.
Zebra TLP 2844 - [Click To Preview Brochure] Citizen 621z - [Click To Preview Brochure]
If you require the quote for labels printer or labels. please contact us, or provide us your contact no. so that our sales men can reach you.
Kirubakaran Trridev Labelss Mfg Co www.trridevlabelss.com Mobile 96000 07995 Email : Kirubakaran.rv@gmail.com
Posted on Sep 04, 2010
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
How to print label on b-sx4 label printer
You must use the option send file to printer in the seagull driver not print else it is converted to graphics and sent to the printer.
May 16, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Printing pre cut labels with no black mark back and the printer is printing one or two labels then missing 5-10 before printing another 1 then missing some. This only happens with one type of label and has...
Dear Emy8,
Try out the following.
1) Check Printer Calibration - by pressing the power button three times - the led color changes -
if not try calibrate - in advance setting options in print properties.
2) Try to create the new label format - instead of using the existing label format
3) Check the label gap - it used be 3 mm by default, might change upon your request. but the gap should be even and gap used exist for sure.
try out these, if still problem exists, update us, we will ask our technician to come up online and trouble shoot them via teamviewer.com
TRRIDEV LABELSS MFG CO total barcode solutions www.trridevlabelss.com Chennai - Tamil nadu - India
Jan 21, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Dear sir or mam ,i m having argox GE200 barcode printer which is not responding. when m giving print no response from the printer and any error also not showing.wat to do?
Hi.. Just follow these steps, hope this may trouble shoot your barcode printer.
1) Restart Your Computer/ Barcode Printing S/w / Barcode Printer/ and try now.
2) Even if it does not work, check the cable connectivity with printer and system
3) Even it is not working, try printer calibration or labels feed options in printers.
4) Check the proper sensor adjustments in printers,
Hopefully this should help you to get back your barcode printer online.
If you have any other queries with barcode printers, please email/contact us.
Regards Kirubakaran.Rv Web Marketing Manager Trridev Labelss Mfg Co Leading Labels Manufactures In Chennai Mobile - 96000 07995 www.trridevlabelss.com email kirubakaran.rv@gmail.com
Sep 03, 2010 | Argox OS-314 Label Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Programmatically printing using C#
You can print labels with windows driver or sending scape commands. If you have problems with the escapes you will design the label with bartender (you have a demo in the CD) and when you have finished with the design you can print to a file. Open that file and you will find all escape command needed to print.
Jan 23, 2009 | Toshiba B-SV4D Label Printer
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Open Questions:
We are using this label printing with vb code & problem is that when we give print 20 qty or more then 10 qty then prints only 10 qty .& error gives run time error ' 52 ' "bad file name or number". please give me solution .source is Private Sub PrnBarCode() Open "lpt1" For Output As #1 Print #1, Chr(2) + "c0000" Print #1, Chr(2) + "KI503" Print #1, Chr(2) + "O0220" Print #1, Chr(2) + "f330" Print #1, Chr(2) + "KW0150" Print #1, Chr(2) + "KI7" + Chr(1) Print #1, Chr(2) + "V0" Print #1, Chr(2) + "L" Print #1, Chr(2) + "H14" Print #1, Chr(2) + "PC" Print #1, Chr(2) + "A2" Print #1, Chr(2) + "D11" Print #1, Chr(2) + "191100201140051" + "HERO HONDA MOTORS LTD." Print #1, Chr(2) + "19110010103001734" + "BASANT LOK, VASANT VIHAR, NEW DELHI-110057" Print #1, Chr(2) + "191100100890007" + "Part NO." Print #1, Chr(2) + "191100000650006" + "SIZE DIMENSION" Print #1, Chr(2) + "191100100530007" + "QUANTITY" Print #1, Chr(2) + "191100100420008" + "PKG.MONTH &YR" Print #1, Chr(2) + "191100000630128" + "MRP INCL. OF ALL TAXES (IN RS)" Print #1, Chr(2) + "111100000560216" + "(PER PACK)" Print #1, Chr(2) + "111100000550150" + "(PER UNIT)" Print #1, Chr(2) + "191100100420088" + Str(Month(CDate(Now))) Print #1, Chr(2) + "191100100420100" + "/" Print #1, Chr(2) + "191100100420106" + Str(Year(CDate(Now))) t = TxtProduct.Text + "/" + txtidno.Text Print #1, Chr(2) + "1e2202000160037B" + t Print #1, Chr(2) + "191100200890082" + TxtProduct.Text Print #1, Chr(2) + "191100100650085" + "-" Print #1, Chr(2) + "191100100520086" + TxtQty.Text Print #1, Chr(2) + "101100001040247" + "(SP)" t1 = Str(Val(TXTMRP.Text)) + Str(Val(TXTMRP.Text)) * 12.5 / 100 T2 = t1 * TxtQty.Text Print #1, Chr(2) + "191100200420216" + Str(Round(T2, 2)) Print #1, Chr(2) + "191100200420151" + Str(Round(t1, 2)) Print #1, Chr(2) + "191100200760083" + TxtPrdDesc.Text Print #1, Chr(2) + "191100100780007" + "DESCRIPTION" Print #1, Chr(2) + "Q" + "1" Print #1, Chr(2) + "^01" Print #1, Chr(2) + "E" Close #1
May 30, 2011 | Argox OS-314 Label Printer
Argox OS-314 Label Printer Logo
118 people viewed this question
Top Argox Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
sahoo_sanjay
bvmihai
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
