Question about Hitachi 43UWX10B 43" Rear Projection Television
Picture Color is Malfunctioning
I purchased this unit new in August 2002 and have had no previous problems. But last week my color RED is now showing as a deep purple.
I cannot get it to adjust correctly and produce any RED on known RED items such as a Nebraska jersey, which is RED. No adjustments I try work, nor will it allow me to select Auto Color Adjustment on the Advanced Settings - Video dropdown. Please advise on a fix and if it is cost effective to repair the TV i.e. (approx. parts cost & ballpark service/tech charge). I don't want to pour alot of money into it, given it's age(6 yrs), and the fact that although it is a HDTV it does not have a HD USB cable port for my HDTV dish box.
    Genius:
  • 1,694 Answers
You will need a serviceman to check the voltages at the red CRT pcb to see if B+ is normal and then decide if RED CRT is defective or not......T.
Posted on Dec 17, 2008
Lost the color red
theres a digital module that comes with the light engine..but your gonna spend some dough..probably only available with a complete light engine replacement..sry
Jan 08, 2014 | Vivitek V37655 56" DLP TV
I have naturally dirty blonde hair, and about 7 weeks ago I dyed my hair for the first time using a demi permanent 6R medium red brown. The color came out like the little mermaid, and since then it has...
If you have a beauty supply store near you, like Sally's, purchase Roux Fanci Full Styling Mousse in one of the blonde shades to tone down the red. This product works really well and provides a wide variety of colors,
Jul 19, 2011 | Clairol Pro Creme Demi 3R Medium Red Brown
Rylee just advised me that I had a convergence problem with my Panasonic PT-47WXC43 which could cost 300-350 to repair. The TV is approximately 7 years old and I'm aware there are a lot of bulbs and other...
I replied your previous question, click HERE to read it again.
If tv shows bright picture in proper focus then it would last few more years as it is rear projection tv that has 3 picture tubes (red-green-blue) to project color picture on front screen.
Its your choice to have new tv instead of repairing this one and yes, its correct that 32 inch tv is available under 700-800 dollars.
Hope these info will help you.
Thanks.
May 26, 2010 | Televison & Video
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
My tv is showing blue when i turn it on i think my blue projector light is out?
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Nov 06, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Color fading, orangy red, video adjustments don't fix.
if it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
Apr 08, 2017 | Televison & Video
Too much red color in the picture
SOUNDS LIKE U HAVE LOST THE GREEN OR BLUE COLOR GUN
Aug 27, 2008 | Hitachi 51G500 51" Rear Projection...
RCA CTC203 no red colour
Did you change the resistor by yourself? I am not sure if your TV has manual adjust on the back of the TV that you can adjust. Some times turning the TV Off and unplug it from the wall helps because it resets the TV. Check your Back ground color and see what is the dominating color. Blue, Green or Red. If this doesn't work please call a professional to look at it.
Jun 18, 2007 | RCA F27649 27" TV
Toshiba 32A41 TV -- color problem
Toshibas are notorious for developing shorts in the inernal guns of the picture tube. In your case the green gun is shorted to G1. The noise you heard was an internal arc between the elements. It is unfortunate however, the repair of this problem usually requires the picture tube to be replaced. Sometimes a savvy technician with sencore picture tube rejuvenator can remove the short. This however usually does not last. Scrivitron
Jun 16, 2007 | Toshiba 32A41 32" TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
