Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
you can have 3 main problem 1) test the power cord for open or faulty 2) test any colder join in the main PWB 3) the power supply is faulty , repair or replace.
you can try cleaning the connection from the main board to the back of the lens assy, if that doesn't work you will likely need a new main board or a dmd board for the lens assy.
SE refers to a sensor error, remedies include checking all connections plugs:
§ The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in
the MOTOR.
?_? reconnect or repair the contact in the connector
The electric contact between the connectors
(5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is
bad or unstable.
?_ Reconnect or repair the contact in the connector
? The connector (6 pin, male, natural) in the Wire Harness is not
connected to the connector (6 pin, female, natural) of PWB
ASSY(Main) or the electric contact of connectors is bad/unstable.
? The electric contact between the connectors ¡a6 pin, male in the Wire
Harness and 6 pin female in the controller(Main)¡bis bad or unstable.
? The Wire Harness between Hall Sensor in the MOTOR and PWB
ASSY(Main) is cut(open circuited).
?_ Repair/replace the damaged WIRE HARNESS
? The Hall Sensor is out of order/defective.
?_ Replace the Motor
? The controller(Main) is out of order/defective.
?_ Replace the PWB ASSY(Main)
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
On the XF-45, you push the "UP" button and then the "Menu" button and hold both of them for approximately 20 seconds. After that you will see a bunch of numbers in the top left hand corner of the screen. Using the Left and Right arrow keys, move the "Group" number until it reads 111. Then using the Up and Down arrow keys to scroll through each lamp (0-3).
If you move the "Group" number to 110, you can see total number of hours that socket has run.
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
