What's your problem?how do i set my old computer to factor settings
I want to know how to put my computer back to factor settings
    Sergeant:
  • 310 Answers
You will need to put the windows disc into the cdrom drive, and set the bios so it boots from cdrom first,
if you didnt get a windows disc you should have been asked to make a recovery disc when you first bought the pc, and same procedure with setting bios.
Posted on Jun 20, 2012
SOURCE:
98 Olds van, how does the high/low cooling fan work?
I'm showing three fan relays in the wiring diagram.
The fans are powered by two 30amp maxi fuses. The relays and fan motors are grounded thru the engine computer. The computer takes input from the coolant sensor and the ac control to decide when fans are needed. You would need to know if the computer is grounding the relays, and if not, why not. You may need a scanner to monitor computer output.
Jun 28, 2013 | 1998 Oldsmobile Silhouette
HP DC7800 doesn't wake up (and power switch does nothing!)
Bad setting. If you press and hold the power button, the computer will shut off. That will keep you from having to unplug it.
Jan 28, 2013 | HP dc7800 Business Desktop Small Form...
Inspiron 1000 doesn't save cmos settings
Hi
As you said that you haven't used the computer for long time then it could be the motherboard which has gone faulty not the HDD or DVD.
Try to use the new HDD with this old motherboard.
Or else you can seek help of Any Geek Squad or computer vendor.
In case if you have any more trouble do contact back in Fixya.
Thank you
Sep 05, 2012 | Dell Inspiron 1000 Notebook
I have an LG LED LCD TV, about 6months old. The remote control is not working, despite battery change and the touch sensor panel is not working either. This occurred last night and it is stuck on the same...
If the touch panel on the tv set is also not functioning as it should, then the tv set will either need a 'factor reset' or be serviced by an LG approved service agent.
As this set is only 6mnths old, it will still be covered by the manufacturer's 1yr warranty and should be repaired at no charge.
Cheers,
Aug 28, 2011 | LG Televison & Video
I put the timer on my lamp and it stays on even if it's not the time that I set, and then it turns off when the time is up... Why does it stay on? And not go according to the timer?
For digital timer:
1) Timer is defective
2) Conflicting programming so timer does not perform as expected
3) Timer not set to correct mode.
4) Program 'off' is set correctly, but program 'on' is not set or 'on' time conflicts with other programming.
5) Current time not set correctly
6) Polarity on outlet is reversed or noise on the line. Check outlet with circuit analyzer.
7) Combination of factors listed above
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Jun 26, 2011 | Woods Indoor 24 Hour Digital Timer (59203)
I tried to upgrade the memory from 1 GB to 2 GB, but after that the computer's screen won't turn on, and i can hear three long beeps and two short ones
The beeps indicate memory issue.
Acer Aspire One Notebook supports upto 1.5GB of memory, so if you try to install 2GB it will not work.
Size 1.0 GB / 1.5 GB (max)
Technology DDR2 SDRAM - 533.0 MHz
Form Factor SO DIMM 200-pin
You can also Click Here to check the specs on the Cnet website.
Regards,
Shrey
May 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Set aspire one d225e to factor settings
hi
to go for Factor setting you have to have Recovery DVD then only you can do that if you don't have
then just reinstall windows if will be fer-she has like a new PC
May 30, 2011 | Aspire Computers & Internet
After installing a sata drive with xp home i took my old hhd and put it on the cable with another hhd on the same cable . Now mthe primary hd 0 and 1 are not found and f1 to continue then it will load x...
First, do you have a 40-wire or an 80-wire parallel-ATA ribbon-cable?
If you have the 40-wire cable, you need to set the jumpers on both of the old drives.
Set one disk-drive to 'master' (maybe also add 'with slave present').
Set one disk-drive to 'slave'.
If you have the 80-wire cable, you need to set the jumpers on both of the old drives.
Set both disk-drives to 'C(able)S(elect)'.
Is the new SATA drive just a "data" drive, or did you install Windows onto it?
May 27, 2011 | Computers & Internet
I change my video card settings in Bios to AGP, after that, i already installed my video card, but no display appeared, ican't restore my video card setting to previous settings because my monitor has no...
if you still have old video card remove the new one and replace with old one
change setting back in bios
then reinstall new card and instead of changing through bios just start computer it should automatically change settings for you
please let me know
May 03, 2009 | Computers & Internet
Computers & Internet Logo
Alun Cox
