Question about TP-LINK TL-WN727N , 150Mbps Wireless Lite N USB Adapter (845973050412) 802.11b
Connecting a tp link wireless usb adapter to xbox 360
Will this connect to xbox 360 for online gaming?
  • 3 Answers
It is not possible to use generic usb wireless adapters with the Xbox or Xbox 360 game console. By connecting a tp link wireless usb adapter to xbox  - 8246b47.jpgJohn Anderson Jun 20, 2012
The post John Anderson is correct that this would not work with a XBOX device. These are intended for and installed on computers (laptop or desktop) with which you would need to install drivers for it on. There is supported drivers that will allow the installation of this device into either a XBOX or PlayStation gaming console.
Best Regards!TP-LINK Support Teamhttp://www.tp-link.com/us/supporthttp://www.facebook.com/TPLINK
Posted on Jun 20, 2012
    Sergeant:
  • 310 Answers
5 Suggested Answers
SOURCE:
  • 40 Answers
SOURCE: I bought a TP-LINK TLWN7200ND
i have used a similar adapter on windows 7 as well as on ubuntu 10.04 (linux), and it detects it upon restart without any external drivers.
try on a system with any of these to confirm that the adapter is good. this could be a hardware fault.
also, try changing the card slot as there could be a problem with the slot.
if it works fine on these, then make sure you are using the correct drivers (the ones exactly for this device and not for another similar device)
Posted on Jun 08, 2011
  • 289 Answers
SOURCE: Today, I was using my
There appears to be some interference from external sources. Check if:
  • Your router is near anything that can give any microwave radiation
  • Your router is anywhere near a freezer/refrigerator
  • Your router is near any device that gives off any interference
You might need to boost the signal in the router. Try using the device on a computer that is closer to the router and check if the fluctuations still occur. If they do you might have a faulty adapter and you may have to return/replace it.
Posted on Jul 06, 2011
  • 161 Answers
SOURCE: Hello, I have a connection problem
try to turn off your router for 1 minute then turn it on.let your router initialize then connect your desktop again..i hope it helps...
Posted on Jul 19, 2011
SOURCE: I bought a TP-link TL-WN821N
Dear Joeri_troch This is Howard from TP-LINK Support Force. Could you please check if your desktop has recognized the wireless adapter? And can you see Wireless Network Connection icon?
TP-LINK Support Force http://www.tp-link.com/en/support/ http://www.facebook.com/TPLINK
Posted on Sep 19, 2011
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
I have installed it onto my computer and done everything the manual says and I have the USB model WNA3100. On the box it says that it is capable of connecting to consoles to support multiplayer gaming. I...
In order to do that you would have to plug this into your xbox 360, not your computer. HOWEVER, Microsoft only supports their own wireless adapter for the xbox 360 .... this one: http://www.amazon.com/Xbox-360-Wireless-Network-Adapter-Networks/dp/B000B6MLV4
I have also heard that wireless gaming can have lesser results. But if you want to do Xbox Live wireless, you will have to have a router and Microsoft's XBOX wifi adapter shown in the link above.
To connect to Xbox live, your best bet is to (if you dont have one) get a router, connect it to your Internet modem, and plug it into the xbox 360 using an ethernet cable.
Mar 08, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
Hoe do i system link
Let's say you have a xbox system in the living room and one in the bedroom both playng sr2. On the back left hand corner above the a/v (audio, video) cable there is a usb port (If you have a wireless adapter you'll need to remove it to access it. You would connect 2 consoles using a usb cable and possibly up to 16 consoles on a network (sr2 allows for a system link between 2-12) now to network you would need an ethernet hub or switch with enough ports to connect the consoles together or each individual console would need its own wireless network adapter to play online. The networking hub would be for a large game room with multiple tv's and console's to group together and play. hope this helps let me know if you have any other questions
Jan 02, 2011 | THQ Saints Row 2 for Xbox 360
Cant connect to internet using internet stick
The internet stick you have would be a USB device which is not supported by Xbox 360, you can connect to Xbox 360 wirelessly or through a wired connection
One way of connecting wireless internet is through the ethernet cable to a laptop paired with your wireless router, or you would have to buy a Wi-Fi adapter for Xbox 360 which retails around $90.
Since Xbox 360 does not have a software like a PC, it is unable to recognize the USB internet stick you have as a internet connection, it may probably end up showing it up just as a USB device on the system settings menu on the Xbox 360 dashboard
Jan 22, 2010 | Microsoft Xbox 360 Console
I have a wireless router hooked to my computer & my son recently got a wireless-G USB adapter so that he can play his xbox 360 online. Will this work, or will we have to put the router on the xbox...
XBOX 360 will only work properly with a 'genuine' USB WIFI adapter designed specifically for it (and at an over inflated price IMO!).
One popular way to play 'network' via the internet is to connect the XBOX 360 to your PC via Ethernet cable and have the PC connecting to the internet either via another ethernet connection or more likely via a Wifi connection which could be via your USB adapter connected to your PC and talking to your Wifi Router)
Dec 26, 2009 | Computers & Internet
Xbox live
Well, you arent supposed to connect them together to play xbox live. You would need to connect them to your wireless network and both of the xbox 360's wouod need to have a wireless adapter. With these ,you could connect to xbox live, or use system link and connect the two.
Apr 27, 2008 | Microsoft Xbox 360 Console
Link Your Console to Another Console
Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
TP-LINK TL-WN727N , 150Mbps Wireless Lite N USB Adapter (845973050412) 802.11b Logo
2,355 people viewed this question
Top TP-LINK Computers & Internet Experts
 Mike M
Mike M
alex metro
alex metro
Jeff richtman
Jeff richtman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
