Question about HP Color LaserJet 2600n Printer
Replacement toner cartridge chip not registering--1000.1 supply error
I refilled my toner with a refill kit that came with a new chip. The chip did not look exactly the same. When inserting the following comes up: 1000.1 Supply Error. I cannot get the printer to recognize it. Is there a way to override the original chip. I tried a magnet but no effect. I have a filled cartridge but no way to print. HELP
  • Anonymous Mar 20, 2014
    how do i (we,all of us being ripped off by microboards) fix this problem
Use the override supplies out feature on the printer.  If the error still stops the printer from working put in the old hp chip and again use the override out setting. GO TO >system setup>print quality>replace supplies>override out,
Posted on Oct 26, 2007
  • Joyce Pyle
    Joyce Pyle Mar 05, 2014
    I can't find "replace supplies/override" option anywhere.
Replace the Toner
Posted on Mar 24, 2008
  • 624 Answers
This won't help you now, however, I used to use refilled cartridges but I always kept a brand new HP cartridge as a spare to deal with that unexpected problem that always came up when I had to print something important. As far as fixing you immediate problem goes I suspect your quickest fix is going to be going to the local store and buying one.
Posted on Feb 02, 2007
    Problem Solver:
  • 18 Answers
Actualy there is something better than going and getting a newone, HP changed there chip configurations a little while ago and the old chips no longer work, i would sugest going to your local cartridge world and having them put on a new chip, i dont know how much this will cost you be negtiate with the manager there and see what they can do. the current supplier of the good HP 2600/2605/1600 chips is static control, the chips from uninet sometimes dont work. that is the best quick fix i know of.
Posted on Sep 07, 2007
REPLACED THE TONER CARTRIDGE WITH A REFILLED ON AND GET THE ERROR MESSAGE "SYSTEM ERROR F2-70"
Most Copier Cartridge have chips on them that tell the copier I am new, Replacing the toner/refill, does not change the chip info as long as the chip says I am empty its empty to the copier, replace the cartridge with a new OEM cartridge.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 17, 2015 | Sharp FO-2081 Copier
Konica error code c-2553
replace the magenta image unit
try this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 16, 2014 | Konica Minolta Bizhub C250 Magenta Toner...
Toner error
There are chips on the toner cartridge, that how the printer known it got a new cartridge so refilling does not work.
Jan 05, 2014 | Konica Minolta PagePro Office Equipment &...
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
Error toner is empty replce the toner even though the toner is new
Toner cartridge original or refill?
In the refill toner cartridges sometimes no replace the chip on it,put a new one chip.
Aug 14, 2011 | Samsung SCX-4828FN All-In-One Laser...
Does a Dell 2330 printer toner cartridge need a new chip when refilled with toner?
Check dell printer driver support number 187777@88@969@ anytime & get fast resolution dell printer support phone number in usa.
1-877-778-****-dell-printer-tech-support-phone-number-1877-jkyrmota2pdsmwgougvljebf-5-0.jpg
Mar 10, 2011 | Office Equipment & Supplies
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
How to refill toner HP Q6000A?
HP unfortunately uses a proprietary chip on their cartridges that renders normal refilling useless. You have a couple different options:
1) You can purchase an aftermarket toner cartridge.
2) You can get your hands dirty and ATTEMPT to do it yourself.
If you want to get your hands dirty, purchase a refilling kit, easily obtainable on eBay. See below link to an eBay search. The kit is made for the average person and includes the special reprogrammed chips for the refilled cartridges.
By far the easiest option is to just purchase a new aftermarket cartridge. However, with enough know-how, you can refill it yourself.
http://tinyurl.com/qlqf47
Jul 16, 2009 | HP 645A Magenta Toner Cartridge (C9733A)...
How do you refill hp cb436a
HP unfortunately uses a proprietary chip on their cartridges thatrenders normal refilling useless. You have a couple different options:
Ifyou want to get your hands dirty, purchase a refilling kit, easilyobtainable on eBay. See below link to an eBay search. The kit is madefor the average person and includes the special reprogrammed chips forthe refilled cartridges.
By far the easiest option is to justpurchase a new aftermarket cartridge. However, with enough know-how,you can refill it yourself.
http://tinyurl.com/pedczh
Jul 06, 2009 | HP 645A Magenta Toner Cartridge (C9733A)...
Reset drums for c5500
I have the same problems many of you have with the Toner and drum error on my C5500N. I have not had much luck with Okidata support. I have had success replacing the chips in the toner cartridges. The replacement chips can be obtained from www.printerdoctor.com. They sell toner refill kits for the printer as well as chips for the toner cartridge and replacement fuses and rebuild kits for the drums.
Oct 06, 2008 | OKI C5500n Printer
HP Color LaserJet 2600n Printer Logo
1,322 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
