Rpc server is unavailable when installing printer
I'm running Win XP Home EDition and I'm logged on as the Administrator. Everything was working fine then all after installing clean Operating system. printer is unable to be installed on that machine. I've tried to add my hp printer using the "Add Printer Wizard to add the printer, received error message "Operation could not be completed." The hardward wizard states there was an error during installation "RPC server is unavailable." Device Manager shows no problems but no printer installed. need help please...
    Habit-Forming:
    New Friend:
  • 15 Answers
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Posted on Apr 27, 2017
2 Suggested Answers
SOURCE:
acdr
  • 1913 Answers
SOURCE: I need help for printer installation.
remove temp files from your computer.then try.
free psace from c: rot driver
Posted on Jan 03, 2009
Rpc server error installing driver
Hi. Have you try to install the printer in other pc ?. It seem to be a pc software error
Feb 10, 2018 | Canon Office Equipment & Supplies
When I log in it say's RPC server not available and restarts it's self
First you can uninstall your printer driver then restart your pc. After that install your printer driver and also need restart your computer. Now try it. Thanks a lot
Nov 09, 2012 | Office Equipment & Supplies
I have installed hp laserjet 1000 on server 2003.I have shared this printer to my network.I am even able to print from client machines remotely.But one of my client machine shows 'The RPC server is...
RPC service may not be available or started on the client machine.
To start/ enable it go to 'Run Command' and type 'services.msc' , locate REMOTE PROCEDURE CALL (RPC) and start the service.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 07, 2010 | HP LaserJet 1020 Printer
This problem occurs because of a mismatch in the computer name and the name that the RPC service expects. This mismatch may occur if the computer name is changed by using one of the following methods:
  • The Microsoft System Preparation (Sysprep) tool was used to create the Windows XP image that you used to start the computer.
  • You change the computer name during the Windows XP Out of Box Experience.
  • One or more of the following conditions are true:
    • You disconnect the network cable during the Windows XP Out of Box Experience.
    • You do not restart the computer after the Windows XP Out of Box Experience has completed.
    • You open Disk Management.
To work around this problem, restart the computer at least one time after the Windows XP Out of Box Experience has completed, and before you open Disk Management
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section.Microsoft is researching this problem and will post more information in this article when the information becomes available.
APPLIES TO
Microsoft Windows XP Professional
Microsoft Windows XP Home Edition
May 03, 2010 | Microsoft Windows XP Home Edition
Driver not getting installed - LBP2900B
where i can find driver for
Canon LASER SHOT LBP2900B
Jun 13, 2009 | Canon LASER SHOT LBP-2900 Printer
The computer displays error "RPC Server is unavailable".
It may be that you have a static value in your registry's field PagedPoolSize, we need to make this "0" (zero). check the steps ->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Jan 29, 2009 | Brother MultiFunction Center MFC-440CN...
The RPC server is unavailable
Goto Run and type services.msc...and then there u have to restart the RPC service..
Dec 11, 2008 | Lexmark Z611 InkJet Photo Printer
RPC Service not running
Please restart the service of RPC.
Write the script for RPC services by the help of google ur problem will be shortout .
Regards
MAYANK GUPTA
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
Solution #1posted on Dec 23, 2007 by Silan
Try :- http://www.fixya.com/support/t311909- printer_installation_problem
1.open a Command Prompt window(click start--
-->run--->type cmd and press OK)
2.key sc config spooler depend= RPCSS (note
the space after depend=) and press Enter.
Try reinstalling the printer.
Or
1. Start / Run / MSConfig / OK.
2. Select the Services tab.
3. Make sure that each of the following
services is checked:
Plug and Play
Remote Procedure Call (RPC)
Remote Access Auto Connection Manager
Remote Access Connection Manager
4. Press Apply.
5. Press Close.
6. Press the Restart button.
Try reinstalling the printer software. If the
issue does not resolve Please get back me.
Thanks
Dec 20, 2007 | Lexmark Z611 InkJet Photo Printer
"The RPC server is unavailable"
I?m assuming this is happening on a Windows machine. This is one of the really vague error messages that Microsoft give for an incredibly large number of problems. I typically see this on servers but have seen it occur on workstations. If you?re running XP, 2000 (server or Pro), or 2003: - Check and make sure your Remote Procedure Call Service is running. - There is an older vulnerability that tries to use a flaw in the RPC services. It is fixed if you copy of Windows is up to date so make sure it is. - Review your application log for any clues. If you need more assistance let us know your operating system, if it is fully patched and what is showing in your log file around the time you receive the error message.
Jul 07, 2007 | ASUS P5S800-VM Motherboard
95 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
