Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59 wave
I have a RCA HD52W59 I replaced the fuse for the convergence problem and now I have a up and down fast wave kinda like im drunk. Anything on the convergence board by the flyback I could of knocked or anything?
  • 1 more comment
  • Lee hatley Dec 04, 2008
    to the right
    ack hit enter to soon. the fuse is to the right of the flyback a set of 3 brownish it was the middle one. for the convergence going out problem.
  • ladywinn
    ladywinn May 11, 2010
    Which fuse did you replace on deflection board? I can help you repairs on thse sets easy money.
  • RCA Master
  • 5,138 Answers
OK those are the correct fuses one in middle does cause lost of convergence FL231,recheck second ribbon connector, make sure it is in correctly also ck cp 150 it will be a green and gold writing on capacitor 2200uf 16v ,see if it is bubbled on top if so replace it and 2 other caps 220uf 35v,what you are saying about it waving could be a big capacitor on small AC board where ac fuse and cord plugs into ck them .Let me know if you need more help . Resolder all connection pinns on flyback.
Posted on Dec 04, 2008
I see a possible fix for missing convergence on a rca hd52w59 by replacing the convergence fuse. I've looked all over and can't find it. If it really has this fuse, where is it??? Thanks
If your looking in the rear of the set on the far left side you will see a large black HV transformer that has a large red wire coming from its top. Thats the flyback transformer look directly to the right of that and you will see three small brown rectangles with FL221, FL231 and FL251 stamped on it. The center one is FL231 if thats blown the set will have a 3D look and the auto convergence feature will no longer be listed under the setup menu.
Dec 18, 2011 | RCA HD52W59 HDTV Projection Television
Hd52w59 Convergence - DL231 replacement
DL231 is a fast recovery diode and should only be replaced with another MUR160 diode.
Mar 01, 2010 | RCA HD52W59 HDTV Projection Television
My RCA HD52W59 HDTV has a convergence problem. It
On your Deflection Board it is the bottom left hand side board has FBT flyback transfomer on it Blowed Fuse FL231 it will be on right hand side of FBT there is 3 of them in a roll small brown rectrangler looking caps but they are fuses ir will be the one in the Middle Call 1-866-925-7278
Dec 31, 2009 | RCA HD52W59 HDTV Projection Television
Rca convergence ic's
RCA projection televisions usually utilize descrete component to achieve convergence. The most likely candidate for this problem is a small fuse that is open on the back of the deflection board. This is usually caused by a cracked soder joint. Either at one of the pins of the IHVT or the rectifier connected to it. Re-soder all of the points on the fly-back transformer and replace the fuse. This should correct your problem.
Dec 20, 2009 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
Hd52w59 convergence fuse
what is wrong with you television ... does not have convergence. did you replace the fuse
Nov 25, 2008 | RCA HD52W59 HDTV Projection Television
in the tips and tricks section under ther fl231 article. This article explians why this fuse fails and how to fix it. it is my belief that is is bad solder connections.
Nov 17, 2008 | RCA HD52W59 HDTV Projection Television
Replaced convergence fuse tv worked then shut down
Sounds like the convergence power supply is defective. If you need more info let me know
Apr 29, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD Projection TV Model HD52W59
you have a fusible link that has blown. This is what causes the convergence option no be erased from the menu. You will need to locate the blown link and replace it. They are identified by FLpreceeding the location number on the circuit board such FL221 and etc.
Mar 23, 2008 | RCA P61927 61" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
