Question about Philips Magnavox MPD845
AV input from a game console
I bought the Magavox MPD845 because it had the AV in so I could hook up a game console for play (Specifically the Gamecube).
I used the cord adapter that came with it (The one turning the single-prong into the three standard RCA hookups) and attached those to the Gamecube's outgoing RCA using some male-to-male end adapters. Colours are all consistent, I've triple checked; the DVD player and cables are new out of the box and the GC cables are fine as well.
The DVD player says it is not recieving input signal. Is what I'm trying to do (Use the player as a sort of portable screen for the console) possible, and if so what am i doing incorrectly? Thank you for your help.
Try using the RED, YELLOW , and White connections in different holes soemtiems they get crazy and swap video yellow, to video red instead of video being yellow on both ends, figure out which one is the video cable by trying all 3 , to all 3 connections on your tv, while both devices are on
Posted on Jan 11, 2009
I can not figure out how to put my Toshiba M454 to Line 1 to play my Gamecube.
  1. Run your AV cords from your Game Cube to your VCR input in the back.
  2. Now run the AV inputs from the VCR (outputs) to your TV (inputs)
  3. Now you press "input" on the remote on your VCR to make the VCR play your input thr Game Cube is hooked up to.
  4. Now you set your TV to what ever input you hooked your AV cable from your VCR to.
  5. Turn the Game Cube on and play.
Regards, Tony
May 04, 2011 | Toshiba M454 VCR
I have a mikomi ctv14440, and it is meant to be able to switch av so that you can plug in a game console,camera in the back.the problem i am having on both sets that i have just bought for my kids is...
The mikomi ctv14440 I have has a scart socket on the back. Plug in an scart to av phono adaptor which has an input/output switch. Set the switch to input and press AV on the remote control. Now you can use the mikomi ctv14440 as an AV monitor with suitable leads. Press TV on the remote control to return to normal TV.
Dec 28, 2009 | Televison & Video
Hooking WII to TV
check your using the correct AV channel for the connection. Try another input connector eg Scart
Jan 20, 2009 | Nintendo Wii Console
Plug in the wii system and everything comes in black and white
Try plugging it into another scart socket, this sometimes happens when a tv does not support 60hz. the result is a screen that has no colour. You could try just plugging it onto the seperate av inputs. Most tv's these days have one scart that will work ok and in colour.
Jan 18, 2009 | Nintendo Wii Console
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Hook up
You can by an AV splitter box from dick smith or even k-mart audio section that allows you to plug all your units into it, then leads go to your TV. There is a switch on the box which you flick over depending whether you want to watch a DVD or play your game unit.
The other option is to have a llok at the back of your DVD player. Some have input AV's (the red, white and yellow holes !) where you could plug your game console into. Then you just leave your dvd plugged into your tv as normal. To play your game console you turn on TV and DVD player. Have TV on "AV" channel as well as your DVD player on "AV" channel (may also be your input or component channel.
Hope this helps :)
Feb 24, 2008 | Televison & Video
Sound not Working Correctly
It could be the TV inputs, or a loose connection in the wires leading to the TV.. in the worst case, the actual AV output device on the GameCube may be damaged somehow.. for this, you'll have to send the GameCube to Nintendo to fix up for you.....
Jun 07, 2007 | Nintendo GameCube Console
Hook up your Xbox to a Dolby Digital Decoder
Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround. Before you get started, make sure you've got the following: A digital audio output. A free optical digital input on your receiver. An optical digital audio cable. Digital Audio Output Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output. Free Optical Digital Input For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver. Ready to Hook It Up? Let's Go! Connect the digital audio output to your Xbox. Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver. Turn on your Xbox with no disc in the disc drive. In the Xbox Dashboard, select Settings. Select Audio. You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital. You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes. You will see Dolby Digital Enabled in the audio screen. Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Philips Magnavox MPD845 Logo
145 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
