Question about Zebra 105SL Thermal Label Printer
I have a Zebra Z400 and when I print a label it ends up printing way off to the left or right even though I have the printer tracking on 'centre'. The labels in use are 47mm wide 25mm long. Would there be an adjustment in page set up? any help would be fantastic. Thanks
Dear Sir,
I am Jitendra Gupta From JSK Netcommerce Pvt Ltd. We provide Barcode Solution and i am working as a technical support. I read your problem so according to me problem is that:-
1. Page Setting Problem:- Please take proper Page size in your software or Printer Driver.
2. Printer Driver:- it may be Printer Driver is Corrupted.
3. Software:- It may be software is corrupted and you should re-install software.
as i think all these process you will clearify you problem and further information you can feel free to contact me. my contact no is 9958217501
thanking you
Jitendra Gupta
40540891/92/96
Posted on Apr 13, 2009
How to adjust horizontal start position of label
is it possible to track the label stock with some guides?? before the printhead sometimes zebras use guides. some zebras also allow you to set a margin in the software or control panel itself.
Jul 11, 2017 | Zebra GX420d Thermal Label Printer
Zebra 105se printer is printing out of the label on the wright side
re donload software for it maby firmware update cheak settings in software ok
Feb 02, 2008 | Zebra Z6M Plus Thermal Label Printer
My zebra z4mplus just start printing at the center of the label instead of at the left side of the label. Instead of a normal full printing on a label, now the left half of the label is blank, and the...
Welcome to FixYa.
The Zerba Driver might have been corrupted.
Uninstall the Zebra Driver/Software from the Control Panel.Re-install the Zebra driver using the Disc that came along with the printer.
Thank you for using FixYa.Have a great day.
Nov 29, 2011 | Zebra Z4Mplus Label Printer
The printer is only printing on the left 1/3 of the label and has a wavey edge at the end of the print.
Sounds like your print head tensioners backed themselves off some or got moved to one side during maintenance. Check to make sure they are in the correct position and are set to the right tension level to ensure proper print darkness.
Sep 07, 2010 | Zebra S4M Thermal Label Printer
Having problems with printer margins. It will print the first label correctly then the next 4 or 5 it will mess up the margins and print out on two labels
You Have to set label size in the printers driver. A hundred diferent label sizes can be used but the driver must know the size to layout the bitmap correctly
Goto printers and faxes then right click on your zebra printer driver. Left click properties and then left click the advanced tab, then left click printing defaults button. In the zebra designer driver size is on this page. The Zebra Universal driver you click a few levels deeper by clicking paper output then paper size. If your size is not listed in the drop down arrow then click customize, then highlight user defigned on the upper left off the screen and enter your correct label size.
May 09, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 label printer only printing left row of labels
I am not sure what you are describing here, if the prints are left justified this is just a setting. If you are saying that the print doesn't come out on the right side there could be several problems. Please find a qualified engineer to assist
Mar 10, 2010 | Zebra TLP 2844 Label Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra printer 140xilll - Too many print jobs?
It does sound like you have a memory overload when you send the 2nd print job. Each label is getting sent to the printer and filling up the memory. Make sure you are using the printer resident fonts and not a regular windows font. The windows fonts get sent down as graphics and take up memory. What zebra is saying to do is store the format of the label in the printer memory and then just send down the information that changes. For example if you were printing a UPS label the basic format of the label is the same but things such as the addresses and tracking # would change.
Jun 23, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Cant print on butterfly label with Zebra TLP 2844 printer
This is a problem of label sensing.
You are probably using the Gap sensor on the 2844, unfortunately the shape of the butterfly labels means you are sensing the wide gap between the labels in the centre, so it will not print anything in the apparent gap area on both ends of the label.
What your label or system supplier should have done is supplied you with the same labels but with a 3mm wide black mark on the underside of the label backing paper, centred between the labels. You can then change the printer sensor setting in the driver to Black Mark. You will then be able to print anywhere between the black marks.
Any problems with this contact us directly at Lancer labels Ltd
Nov 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Jul 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
667 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
