Question about Maytag Neptune MAH5500B Front Load Washer
Won't cycle to the next step
I have a front load washer that starts to fill when set to wash but stops after it fills and will not cycle to the next phase of the wash. I can put it manually on spin and it will spin out the water but I cannot get it to cycle. I have changed the timer unit. The motherboard was replaced last year (third time for this circuit). What recommendations can you give me?
    Problem Solver:
  • 18 Answers
Maytag neptunes are the worst appliances to get. i worked for maytag and the neptunes are over price and break very easy. plus the cost of repairs are very expensive. i would recomend getting a new washer. youve put enough money into this one and getting it fixed is going to be expensive. especially when the fix is only temporary. something else is going to leak or break.
Posted on Feb 04, 2007
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
My front loading washing machine, GHW9100LW2, Serial# CSR2103781 (purchased in July 2004),has started to stop in mid cycle and throw an F 11 signal, and the door will not open. If I cancel the cycle,...
You need to check and replace water fill valve (blue) located on the back where hot water and cold water hoses connected to the washer. It may get stuck due to corrosion in pipe. Part may cost around 35 to 45 dollars. Next item needs to check is Flowmeter (white) connect after water fill valve. When get dirty water cannot get into washer. The water pressure valve is the last thing to check and replace if the problem is not fixed.
Good luck.
Dec 02, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
119 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
