Baby Gear Logo
Anonymous Posted on Jun 20, 2012
Assembly instructions for chiltern arbour
B&Q
Peter
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 01, 2014
Peter
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2384
Points
11
Does anyone have the building instructions for a B+Q blooma Chiltern Arbour (SS235)?
Pitching instructions for a great outdoors executive 320 tent and sunroom
This is a duplicate of a previously asked question on FIXYA from 2012, where an exact set of instructions could not be found, but two proposed answers were given.
For a similar but not the same tent, the scanned document still exists online:
https://drive.google.com/file/d/0B1SdA-vKLONwZ05vTGZKdF9BTzQ/view
https://www.fixya.com/support/t7407226-need_pitching_instructions
Quoting from FIXYA question from 2012
Wollocks
Jim,
these are the instructions I devised as I had no instructions either...
Great Outdoors Executive 320 tent
Two rooms plus a fully enclosable veranda.
(4.9m long x 4.3m wide x 2.4m high)
Main Tent Assembly :
Lay the tent out on the ground (making allowance for the slope of the ground, prevailing wind, general access, etc).
Peg down the main corners and centres of each wall, keeping the tent square and evenly tensioned. Peg down remaining loops.
Assemble two sets of side support poles. These have been numbered (from the front, looking towards the tent (ie, facing the veranda)) :
Left-hand side : L1, L2, L3, L4 & L5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports LF1 & LF2 and LB1 & LB2 (ie, 2 sets of poles 5 & 9).
Right-hand side : R1, R2, R3, R4 & R5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports RF1 & RF2 and RB1 & RB2 (ie, 2 sets of poles 5 & 9).
Place poles in the loops along the sides ensuring that the 4 brown loops (at each end of the sides) are looped behind the projecting studs (this ensures the sides don't slide into the centres.
Lift & tension one side, then the other.
Assemble the centre poles (numbered C1, C2, C3, C4, C5, C6 & C7 (corresponding to poles 12, 13, 8A, 24, 3, 4 & 8)).
Slide the centre poles through the centre of the tent. Use poles 14A & 15 to hold up the rear of the tent, poles 14A & A in the centre, & two further sets of 14A & 15, one set at the front of the tent & one set for the veranda. Tension by expanding the poles.
Assemble poles A, BE, C2, BE & A through the centre of the tent, clip onto ridge poles & tension. (Note : poles A should be inserted from the outside, through the elasticised holes before being inserted into poles BE).
Attach a guy rope to the rear of the tent (top of centre pole 15) & tension.
Veranda Assembly :
Assemble 4 sets of poles (10 & 30) & place in corners & centres of the veranda. Attach guy ropes & tension. Attach veranda walls (using Velcro strips).
Porch Assembly :
Select which side is to be an entrance. Unzip the window covering & use two poles (10 & 30) to lift it. Tension with 2 guy ropes on each pole.
hope the above helps.
Warwick Annear
[email protected]
Instructions for chiltern arbour
Contact the manufacturer on facebook. Message them that you need a copy. I got mine the next day.
https://www.facebook.com/rowlinsongp/
May 31, 2018 • Toys
I have a metamec grandmother clock it chimes 4min early have tried to syncronise it but it still chimes early
If your clock has a round arbour push fit hand it is quite easy to sync. Undo the nut and the minute hand will drop off easily, then gently but firmly pull the hour hand from the centre so as not to put pressure on the hand itself. As soon as the clock chimes, replace the hand exactly on the hour corresponding to the amount of strikes, replace the minute hand pointing exactly to 12 o'clock and replace the nut.
If the hour hand has a square fit arbour and held on by a rivet it is a bit more complicated and I would suggest you take it to your local clockmaker.
Mar 07, 2014 • Seiko Home
How do you change the blade on a Husqvarna partner K750 concrete saw?
The blade bolt is 13mm,on the opposite side there is a hole in the belt guard to insert a 6mm pin to lock the front pulley, once locked undo the blade bolt counter clockwise, once removed, remove the outer clamping flange, you can then remove the blade, the standard arbour is 20mm, this can be changed if you wish to a 25.4mm, or a 22mm, depending on the arbour size of the blade you wish to fit, the arbour just pulls off the shaft with a suitable puller. Refit the the blade and outer flange, tighten the bolt securley.
Jul 27, 2011 • Garden
6helpful
2answers
I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
Paul.
Where do i buy an arbour for dw744 table saw
If you have a type number of 4, an assembly will have to be replaced, not just the shaft. THIS COULD BE DIFFERENT IF YOU HAVE A DIFFERENT TYPE NUMBER. It can be purchased online through DeWalt, but verify your type number before ordering.
http://servicenet.dewalt.com/Parts/Search?searchedNumber=153476-07&searchType=1
I hope this helps!
5helpful
2answers
Need assembly instructions for a 10x12 Wilson & Fisher portable gazebo. Lost instructions.
I looked for hours on the internet trying to find this.
Hope this saves you some time. The manual can be downloaded here.
You can show your appreciation by becoming my scribd follower so you can get all my do it yourself posts.
http://www.scribd.com/doc/55393964/Monterey-Gazebo
thanks
Bill Kibbe
Unable to get the blade or arbour to tilt to a 45 degree anlge. Will only go to about 43 degrees. Cleaned gear shaft arbour moves on with no success.
First look for a stuck piece of wood in the gear tilt area. The other thing is if you don't tilt it that often the track or swivel can get rusty at the ends. try wd-40 on all the moving parts and you may even have to steel wool the track a little... sometimes as the blade tilts a loose screw will allow it to fall out of alignment jamming the arbor. Turn it upside down with the blade fully retracted and unplugged and see if you can give it a push inside as you tern.-- good luck
2answers
Vw golf 2.0 gti, overheating, boiling water, no power loss
Sounds like you may need a new Thermostat.
Get a Haynes or Chilterns manual and a new Thermostat for the carfrom a car parts place like Autozone. Its normally a simple opperation to change it.
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
